SIC requirement for Part 91 ops?
fam62c
Okay, bear with me here this is a dumb question from an airline pilot who has been out of part 91 for a long time but is looking to do some part-time work. What is necessary (what is the pertinent FAR) for a pilot to act as SIC for an aircraft requiring a type rating and 2 crewmembers. Back in the day I think we just needed familiarization with the systems and 3 take-offs/landings. I know for part 121 our guys need an "SIC Type" nowdays, what is required for Part 91. Can you still do the old 3 bounces or has this been superseded by new requirements. Sorry for the dumb questions.
3 bounces and done
A little more to it.
61.55 Second-in-command qualifications.
(a) A person may serve as a second-in-command of an aircraft type certificated for more than one required pilot flight crewmember or in operations requiring a second-in-command pilot flight crewmember only if that person holds:
(1) At least a current private pilot certificate with the appropriate category and class rating; and
(2) An instrument rating or privilege that applies to the aircraft being flown if the flight is under IFR; and
(3) The appropriate pilot type rating for the aircraft unless the flight will be conducted as domestic flight operations within United States airspace.
(b) Except as provided in paragraph (e) of this section, no person may serve as a second-in-command of an aircraft type certificated for more than one required pilot flight crewmember or in operations requiring a second-in-command unless that person has within the previous 12 calendar months:
(1) Become familiar with the following information for the specific type aircraft for which second-in-command privileges are requested—
(i) Operational procedures applicable to the powerplant, equipment, and systems.
(ii) Performance specifications and limitations.
(iii) Normal, abnormal, and emergency operating procedures.
(iv) Flight manual.
(v) Placards and markings.
(2) Except as provided in paragraph (g) of this section, performed and logged pilot time in the type of aircraft or in a flight simulator that represents the type of aircraft for which second-in-command privileges are requested, which includes—
(i) Three takeoffs and three landings to a full stop as the sole manipulator of the flight controls;
(ii) Engine-out procedures and maneuvering with an engine out while executing the duties of pilot in command; and
(iii) Crew resource management training.
(c) If a person complies with the requirements in paragraph (b) of this section in the calendar month before or the calendar month after the month in which compliance with this section is required, then that person is considered to have accomplished the training and practice in the month it is due.
(d) A person may receive a second-in-command pilot type rating for an aircraft after satisfactorily completing the second-in-command familiarization training requirements under paragraph (b) of this section in that type of aircraft provided the training was completed within the 12 calendar months before the month of application for the SIC pilot type rating. The person must comply with the following application and pilot certification procedures:
(1) The person who provided the training must sign the applicant's logbook or training record after each lesson in accordance with §61.51(h)(2) of this part. In lieu of the trainer, it is permissible for a qualified management official within the organization to sign the applicant's training records or logbook and make the required endorsement. The qualified management official must hold the position of Chief Pilot, Director of Training, Director of Operations, or another comparable management position within the organization that provided the training and must be in a position to verify the applicant's training records and that the training was given.
(2) The trainer or qualified management official must make an endorsement in the applicant's logbook that states “[Applicant's Name and Pilot Certificate Number] has demonstrated the skill and knowledge required for the safe operation of the [Type of Aircraft], relevant to the duties and responsibilities of a second in command.”
(3) If the applicant's flight experience and/or training records are in an electronic form, the applicant must present a paper copy of those records containing the signature of the trainer or qualified management official to an FAA Flight Standards District Office or Examiner.
(4) The applicant must complete and sign an Airman Certificate and/or Rating Application, FAA Form 8710–1, and present the application to an FAA Flight Standards District Office or to an Examiner.
(5) The person who provided the ground and flight training to the applicant must sign the “Instructor's Recommendation” section of the Airman Certificate and/or Rating Application, FAA Form 8710–1. In lieu of the trainer, it is permissible for a qualified management official within the organization to sign the applicant's FAA Form 8710–1.
(6) The applicant must appear in person at a FAA Flight Standards District Office or to an Examiner with his or her logbook/training records and with the completed and signed FAA Form 8710–1.
(7) There is no practical test required for the issuance of the “SIC Privileges Only” pilot type rating.
(e) A person may receive a second-in-command pilot type rating for the type of aircraft after satisfactorily completing an approved second-in-command training program, proficiency check, or competency check under subpart K of part 91, part 121, part 125, or part 135, as appropriate, in that type of aircraft provided the training was completed within the 12 calendar months before the month of application for the SIC pilot type rating. The person must comply with the following application and pilot certification procedures:
(3) If the applicant's flight experience and/or training records are in an electronic form, the applicant must provide a paper copy of those records containing the signature of the trainer or qualified management official to an FAA Flight Standards District Office, an Examiner, or an Aircrew Program Designee.
(4) The applicant must complete and sign an Airman Certificate and/or Rating Application, FAA Form 8710–1, and present the application to an FAA Flight Standards District Office or to an Examiner or to an authorized Aircrew Program Designee.
(6) The applicant must appear in person at an FAA Flight Standards District Office or to an Examiner or to an authorized Aircrew Program Designee with his or her logbook/training records and with the completed and signed FAA Form 8710–1.
(f) The familiarization training requirements of paragraph (b) of this section do not apply to a person who is:
(1) Designated and qualified as pilot in command under subpart K of part 91, part 121, 125, or 135 of this chapter in that specific type of aircraft;
(2) Designated as the second in command under subpart K of part 91, part 121, 125, or 135 of this chapter in that specific type of aircraft;
(3) Designated as the second in command in that specific type of aircraft for the purpose of receiving flight training required by this section, and no passengers or cargo are carried on the aircraft; or
(4) Designated as a safety pilot for purposes required by §91.109(b) of this chapter.
(g) The holder of a commercial or airline transport pilot certificate with the appropriate category and class rating is not required to meet the requirements of paragraph (b)(2) of this section, provided the pilot:
(1) Is conducting a ferry flight, aircraft flight test, or evaluation flight of an aircraft's equipment; and
(2) Is not carrying any person or property on board the aircraft, other than necessary for conduct of the flight.
(h) For the purpose of meeting the requirements of paragraph (b) of this section, a person may serve as second in command in that specific type aircraft, provided:
(1) The flight is conducted under day VFR or day IFR; and
(2) No person or property is carried on board the aircraft, other than necessary for conduct of the flight.
(i) The training under paragraphs (b) and (d) of this section and the training, proficiency check, and competency check under paragraph (e) of this section may be accomplished in a flight simulator that is used in accordance with an approved training course conducted by a training center certificated under part 142 of this chapter or under subpart K of part 91, part 121 or part 135 of this chapter.
(j) When an applicant for an initial second-in-command qualification for a particular type of aircraft receives all the training in a flight simulator, that applicant must satisfactorily complete one takeoff and one landing in an aircraft of the same type for which the qualification is sought. This requirement does not apply to an applicant who completes a proficiency check under part 121 or competency check under subpart K, part 91, part 125, or part 135 for the particular type of aircraft.
You need an SIC type if you operate internationally, including Canada and Mexico. For domestic US, 61.55 is all you need.
You can take your logbook containing a 61.55 endorsement and a completed 8710 to your local FSDO and they can issue you a SIC type if you need one.
Do you need a CFI to do the training or will the ATP suffice? I'm a long time airline guy who got back in pt. 91 recently, as well (and too apathetic and lazy to wade through the regs myself).
Someone appropriated rated in the aircraft, he or she could have a commercial with type. No CFI required for the SIC type endorsement.
Not regulatory of course but many insurance companies require a trip to the simulator.
Thanks.
A CFI is not required, but you must comply with this (paisted from previous answer):
So basically the person endorsing you has to have some sort of title, then you need three T/O and landings within the last year, you must also do engine out procedures, and have systems knowledge. My buddy flies his Falcon down to Mexico with a non-type-rated SIC, I wouldn' recommend it but he gets away with it, for now. He was born in Mexico and gets more leeway than most.
Tell your buddy he is breaking FAA regulations and if something happens good luck with the insurance and the FAA
I have told him the same thing! I just shake my head.
All your buddy's copilot has to do to get his SIC type and be legal is take an 8710 and his logbook to FSDO (assuming he actually has done 61.55 training in the airplane). 15-20 minutes and out you walk with a temp...
Sic
International ops require an SIC type in more and more countries every year. Most insurance now wants sim. If you can pass Wyvern, you're in.
Check that airline captain attitude at the FBO door. Corporate is a totally different anmal.
Good flying to you!!
Thanks everybody for the replies. Regarding attitude, I flew 91 before starting with the airlines and I liked it. I wouldn't pre-suppose that all airline pilots have an attitiude. Most of the guys I fly 121 with are great employees and will go above and beyond for the customer and their fellow employees, obviously there are some bad apples out there but they are in the minority. The guys I flew 91 with years ago were great and most of the guys I fly 121 with are great. A truly professional pilot will be professional in any environment be it 91 or 121.
