stingray
Senior Member
- Dec 2, 2001
If your a required crewmember by FAR's LOG IT
If you are a required crew member by OP Specs, which if it is in your ops specs makes it an FAR. LOG IT
If you are a required crew member LOG IT.
When applying for a flying job 135 or 121, you fill out an application with all the pilot jobs you have had, which is also the law. It should also be reflected in your logs
