Scope Confession?
FDJ2 said:
..as it pertains to DAL scope, the only ratios are those which allow a certain level of outsourcing...the number that can be operated by other than Delta pilots...
FDJ2,
If I understand your position, the objective of the Delta scope clause is to restrict "cheaper labor" (small-jets) by ensuring that any small-jets over the number permitted by the scope ratio are operated as mainline aircraft.
If this summarization is correct; then could you please list the contractual mechanisms employed for this purpose, their individual function, and how technically and economically they achieve the desired result?
