A good tip offered to my when working with @Cactus Charlie a few months back relating to saving configuration files for your G3X. Only the configuration side of the G3X offers the option to save the configuration so if you replace your GDU as I had to do, you get to reconfigure the flying side. Not nearly as bad as if you had to redo your system from scratch.
Hold the MENU button when powering up your GDU until you see it entering the configuration mode. Go to the config files option which is around the 4th option on the top row if I remember correctly and you can then press menu to save your config file. I use a dedicated SD card but also save them to the normal SD card that stays in the GDU.
But here's the important part and something to consider prior to saving the config. It will always overwrite the config with the default name. So if you have a configuration already stored, put the card in your computer and rename it. Consider something like G3X_Config_20260101 or if you did something in this config you can put a reminder of the change in the name. Any time you save the config be sure to rename the saved config to one with a new name so you can keep a config history and never overwrite a prior config.
The config will not store your K factor for those of us with fuel flow sensors or if you have tanks with fuel sensors that calibration needs to be manually recorded and restored if the config is restored.
FYI
FYI
