RVSM and Minimum Equipment Lists
flyboydk
If your aircraft is RVSM approved, is it correct that you don't have to have an MEL?
That's the first I hear of it, our airplane is RVSM approved and has both an MEL and a CDL.
I just found this on the FAA website:
FAQ: Minimum Equipment Lists. Is it a requirement to have a MEL before being issued RVSM authorization?
Answer:
Operators are not required to adopt an MEL. If the operator chooses, however, to adopt an MEL, then the MEL must be developed using the Global Change 59.
It was on http://www.faa.gov/ATS/ato/150_docs/FAQ_Mx_10Aug04.doc
