Jeff Helgeson
- Sep 17, 2002
It's all about OPS SPECc and the rules that apply to you.
That is tough question in an interview if you haven't flow 121 and know the ops specs. I would probably give the part 91 answer about inside the marker, you may continue with runway envirnment and preface this may not be the case in the 121 OPS SPECS for your particilar carrier.
As Bafanguy stated OPS SPECS are controlling. They don't make you excempt from the FARs, but they are consider as the same as FARs for the carrier.
Note: Legality to continue and appoach and legal to land may be two entirely different animals.
PC12Cowboy said:Jeff,
I just got another instrument pilot thru the system and the DPE is a retired FAA inspector....and said if you land with the RVR below minimums..its a bust...then a friend blew a skywestinterveiw oral...because thats what was stated and the interveiwer stated flight vis was the most important requirement....ie landing lights....runway enviroment.....always equals the RVR plus 100 if the got something
