thunderworm
the Hoff
- May 12, 2004
I don't see this as a pilot requirement but as a means of the carrier covering itself under G91.6:Appendix G to Part 91 - Operations in Reduced Vertical Separation Minimum (RVSM) Airspace
From Appendix G:I don't see this as a pilot requirement but as a means of the carrier covering itself under G91.6:
(3) Policies and procedures: An applicant who operates under part 121 or 135 of this chapter or under subpart K of this part must submit RVSM policies and procedures that will enable it to conduct RVSM operations safely.
I'll grant that. What I am saying is that the operator is not required to make a recorded check part of their procedures. They are required to check. They are required to report deviations and errors. They are not required to include recording of inflight readings of normal/compliant altimeter readings in their manual. I think the operator that requires this was the issue in the original post. I don't believe other operators do because they chose not to include such a procedure in their manual. This, of course, is conjecture on my part.From Appendix G:
The carrier's application for RVSM authorization includes their RVSM Manual, which pilots are required to follow for operations under the carrier's RVSM authorization. The manual is what requires the record keeping, and of course compliance with Appendix G is required by 91.706.
Our policy not only requires noting the time and altitude of both altimeters (standby not recorded) at entry and exit, but a follow-along notation every hour thereafter. On legs which require additional documentation such as an oceanic, we note this not only on our flight release paperwork, but also on the oceanic charts along with our other position and plotting notations.
