rest period
matthewjohn
Do any of your departments have set hours for a required rest period between trips? (ie. you duty off at 2300 what is the earliest you can show the next day to continue that trip or start another trip. If so do you also know a reason this rule is in effect?)
Safety, fatigue, and common sense are a few reasons that come to mind...
I would speculate you are asking in reference to a FAR Part 91 operation. Although there are no specific rest period and flight time restrictions as with 135, 121, etc., you are still very much required to operate in a safe manner and determine that you and the crew are airworthy just as you would the aircraft. Screw something up without reasonable rest and you could find yourself in violation of 91.13... and then look for the civil suits as well.
Your question is very alarming though. It reads as if you are not in favor of having any minimal limits for rest and flight time. I could be reading it wrong.
Yes, my company has a rest policy. 10 hours between duty days, if a duty day exceeds 14 hours we must get 16 hours of rest.
The reason for any rule should be safety. Fatigued pilots are dangerous.
Our company is very strict about our Duty Day scheduling.
Our dispatch tries not to schedual anything over 12 hours. Anything over this must be approved by our Chief Pilot. Under no circumstance can we work more than 16 hours (that is down time and flying time).
Dispatch can schedual a 14 hour day if a "Day Room" is available at a hotel.
Crew Duty Time
1.0-12 hours = 10 hours rest
12.1- 14 = 12 hours
>14 hours = 14 hours
12 hour duty periods with 12 hours of rest between duty periods. This is adjusted up as the duty day exceeds 12 hrs. Duty day can go up to 13 hours with CP approval and 14 hours with VP of Flt Ops approval. Duty day isn't adjusted for back of the clock ops.
We are part 91 only but basically follow part 135 duty/rest requirments. Its only common sense to have some type of limits. That is nothing more than a safety issue. I know of depts that have no rules and have had 19 hr days:eek: ---not too smart
When you talk about duty day, do you mean flying for #hours or do you count time on ground also? and does one weigh more than the other in terms of importance for a required rest (ie should doing a trip east coast to west and back, flying 8 hours, being on duty for about 12 hours have more bearing than doing a 1 hr flight sitting for 7-8 hours and flying 1hr back for a total duty day of 12 hours?) Should these days require the same amount of required rest after they are completed before the next trip or day can be started?
Our duty day begins when we arrive at the airport prior to a flight and lasts for 12 hours after that. There is no distinction for flight time versus sit time, east/west trips, day/night, etc...just 12 hours on duty. We can extend our duty day if needed, but won't extend it on the back side of the clock. There are different departments within our flight ops and operations in our particular department mandate a hard 12 hour duty day for operational and safety reasons. Other departments use a max 14 hour duty day with mandatory rest provisions following.
When I flew for the airlines, our max duty day was on a sliding scale and adjusted depending on the time of day. I could never figure it out, but it seemed to work well. eg. If you showed for a 2200 red-eye, your max duty day was 10 hours (or something like that), where if you showed at 0800 for a day trip, your max duty was 15 hours (or something like that).
Duty is duty. It doesn't (shouldn't) matter if you're sitting at an FBO, in flight, on call, waxing your jet, etc.
