capt. megadeth
Metal Momma!
- Oct 12, 2003
Agreed. I'm sure you can (didn't look anything up), but why?Dinger said:I imagine you could, but why would you worry about it. You've already launched and your fuel/pax load has been determined. I can see that it may matter if it changed before you pushed back, allowing you to carry less fuel and more pax/bags. I guess I just don't see what good it would do.
I know you asked if you could. I have never seen anything indicating you couldn't.
That's what those "Fuel Dump" switches are for.Dinger said:But once you launch, REMOVING an alternate altogether is kind of a mute point since you already launched with dest + alt. fuel.
First of all as a pilot and a licensed dispatcher we must be clear on what regs were are addressing. Under part 91 rules the PIC is totally in charge of all preflight planning and for the operation of his/her aircraft from start to finish. I second the comments above as it pertains to part 91 ops. I dont see any advantage to canx a good alternate airport on the flight plan.profile said:For 121 operators, how do you handle the following scenario:
1. Alternate required due to ops specs/wx, etc.
2. Alternte weather drops to below min required after departure.
3. Diversion not possible due to environment (International, etc).
4. No other alternates available within fuel range that can be filed.
Do you:
1. Declare an emergency to continue?
2. Declare and go to a divert field?
If you do declare, do you tell ATC this or is this an internal thing?
This can be a real scenario for many parts of the world.
Really, please provide the 121 reg that allows the removal of an alternate while in flight or in any other instance where the alternate was required based on the flight planned weather?FlyChicaga said:Yes, you can remove the alternate if it is no longer required.
Where in the FAR's does it forbid it?rvsm410 said:Really, please provide the 121 reg that allows the removal of an alternate while in flight or in any other instance where the alternate was required based on the flight planned weather?
And second, why would you want to?
Are you saying that if you divert to FLL (i.e. could not get into RSW) that you must still have enough fuel to get to your alternate?FlyingDawg said:Suppose your going to RSW with an alternate of MIA. You need fuel to RSW + fuel to MIA + 45 minutes. If you divert to FLL (change of destination) without dropping MIA as alternate (you might still need it because of 1-2-3 rule at FLL) you will now need fuel to FLL + fuel to MIA + 45 minutes. However if diverting to MIA you only need fuel to MIA + 45 minutes.
But in the case where the weather is not requiring an alternate for FLL then the alternate could be dropped requiring only fuel to FLL + 45 minutes. So I say yes you can drop an alternate.
121.631(C) - can amend for close to anything you want. For example, after departure, you can amend to add an alternate (if youve got the gas), delete an alternate (if you can), a new route of flight to calculate if youve got the gas, etc. Notice all those amendments are to determine if youve got the gas to do something, to adhere to 121.639 and 121.645. The only real reg that applies enroute is 121.627, as long as youre not unsafe; you're cool.rvsm410 said:Really, please provide the 121 reg that allows the removal of an alternate while in flight or in any other instance where the alternate was required based on the flight planned weather?
Lead Sled said:That's what those "Fuel Dump" switches are for.![]()
Hey don't laugh, 20 years a go there was a newbie FE at Western Airlines who tried to balance fuel in one of their 727s by dumping. Her airline career was short lived.
'Sled
Nope, I'm dead serious. She didn't make it through probation.ultrarunner said:You're busting our balls, aren't ya?
I don't think that it got that far out of hand, but it was definately trending in that direction.ultrarunner said:"...Cap't, I've got that fuel balanced....you've got 1000 lbs left, 1000 right, and 1000 center..."
Very true. 121 Supps must always have an alternate on the release. How's life up in the tundra?lithstrip said:If you fly under 121 supplemental you must always have an Alternate listed on the release. All other circumstances under which you can amend the release still apply, We will amend to a closer Alt. if WX allows to gain additional hold time at Dest. or to a different Alt. if the wx goes below derived mins at the Alt. on the release
