Recommended techniques on flying a tail dragger
pumpkinhead
Member
Looking for any recommend reading material, videos or personal insights on learning, (techniques) for flying a tail dragger, specifically a Citabria.
Thank you in advance.
Citabria has spring gear, it will let you know when its not happy. It was my first taildragger, and its a great flying airplane.
Brakes are for taxiing, not for the runway.
Don't try to salvage a bad landing.
The flight isn't over until the airplane is chocked and tied down.
Keep the long axis of the airplane aligned with your direction of travel when landing.
The flipper things by your feet are attached to the rudder. Use them.
Two point, thee point, doesn't really matter. You should learn to do both.
It's just an airplane. Don't let the mythology of conventional gear deter you.
All those fancy memory aids you learned about holding the yoke correctly relative to which way the wind is blowing you will get to actually have to use now. It doesn't have the training wheel up front and you'll need to use proper stick etiquette to keep from flipping on your back. Oh yeah, if the stick ain't in your gut it's not going to land full stall (in a Cub anyways).
Got to www.faa.gov. do a search for faa 8083 3a. Then click on airplane flying hand book. Open chapter 13. Good luck lots of fun and will make you a better pilot!
Before you fly - do lots of fast taxiing. Matter of fact, the flying part of a TW is no different, it's the landing and take-off, or more specifically, the handling of the CG while rolling fast, at near T.O.& Landing speeds.
So,...get on a side taxiway somewhere, or on the runway is best, and power up to get 15-20 kts speed, throttle back, and stomp on a rudder and brake (stick all the way back) and cause a small groundloop. Slow at first, just a fast taxi, then increase speed untill it simulates a groundloop, then practice stopping the groundloop at precise points, ie., 180, 90, etc. this will get you in command of directional control of the nose with the rudder and brakes.
That's what TW flying is all about.
One shouldn't ever groundloop in a conventional gear airplane. If one is unlocking the tailwheel above walking speed, one is going to fast to be swinging the tail. This puts an extraordinary load on the main gear. There's no reason for it, operationally, or when training.
It was standard U.S.Army Bird Dog (L-19) Primary Pre-Solo training.
Yeah, it does work the landing gear somewhat, but it is an excellent training tool, and I guess it is cheaper than a real groundloop.
The US Army had one thing that the civillian world doesn't have: unlimited taxpayer funds. Groundlooping at any speed doesn't just "work the landing gear somewhat." It's extremely hard on the gear and the airframe, and it teaches the exact opposite of what the student should be learning.
There is no reason in the training environment to groundloop the airplane. One can be properly taught to fly conventional gear without inciting a loss of control.
The L-19 had spring steel gear which was a little more tolerant of abuse. Simply because one can abuse equipment doesn't mean one should. That the army elected to poorly teach because the taxpayer was footing the bill doesn't mean it should be done anywhere else. Furthermore, teaching by that method leads to too much reliance upon brakes; one should teach a student to bracket the gear and keep it from escaping into a groundloop without brakes. This is particularly true in many light civil aircraft where the brakes are far short of spectacular; especially in friction heel brakes which are just short of non-existent in practical use.
A big part of teaching someone to flying conventional gear is teaching them not to use the brakes.
19 yrs of flying tailwheels, big an small, never heard of intentionally grounglooping. Also, who would let someone almost wreck their airplane for training? I havnt groundlooped yet, but you know what they say.
The only time one ought to consider an intentional groundloop is to stop a runaway aircraft, when all other means are no longer an option, or when it's the only method of getting stopped in an emergency. Such occasions are few and far between, and have a high probability of making things worse, not better.
So, you never back-taxiied down a short runway and, upon reaching the end, 'unlocked' the tailwheel with a quick 180 into position?
C'mon. I'm not talking about a real fast speed reversal, but slow enough to get a feel for rudder and brakes. 'jeez, Avbug. :rolleyes:
That's not a groundloop, and if you are groundlooping, then you're going too fast.
A standard technique when I first began flying ag, especially on short runways, was to reach the end of the runway, swing the tail and come up to takeoff power as the tail came around, and exit the turn rolling (as opposed to a standing takeoff. This enabled using every inch of the runway, which was necessary. The takeoff were sometimes done diagonally to gain a little more distance, and involved running until the tailwheel got light, then popping full flaps and full forward stick, then aft stick...and the runway was behind. A mile later, enough airspeed was built to begin climbing over the parallel powerlines, then a turn to go to the field.
This is not at all the same as 15 knots. In fact, swinging the tail isn't a groundloop; it's a turn. Swinging the tail at 15 knots during a fast taxi is a groundloop, and a very poor practice.
Now that's what I'm talking about. You said it much better than me. :)
[QUOTE/ Oh yeah, if the stick ain't in your gut it's not going to land full stall (in a Cub anyways).[/QUOTE]
This statement is true, and essential for a three-point landing in a Cub, but a Citabria is not a Cub.
If you land a Citabria in a full stall, the main wheels will be about nine inches above the runway when the tailwheel touches. This will cause an inelegant "flop" onto the runway. The main landing gear legs are too short on the 7 series airplanes to allow a three-point landing in a full stall. The designers fixed that with the Bellanca/Champion - American/Champion "Scout" and put longer main gear legs on the airplane.
You can do a nice three-point landing in a Citabria, but the airplane is not fully stalled when you do it. Perhaps the best way to describe it is a tail-low wheel landing in which the tailwheel happens to touch down at the same time as the mains.
Have fun with your tail-wheel checkout: you're going to have a lot of fun and you won't regret the time and money you spent on it.
Have fun with your tail-wheel checkout: you're going to have a lot of fun and you won't regret the time and money you spent on it.[/QUOTE]
Very true, in fact, as I was reading this thread, I was composing pretty much this exact post in my head. Now I don't have to, good work.
The Cub and the Citabria can both be landed three point easily enough.
Certainly, but a perfect simultaneous 3 point in a Citabria with normal length gear legs is not stalled. You do a full stall landing, the tailwheel *will* touch well before the mains.
That really depends on the person performing the landing. One can stall level or nose up, and one can do a full stall landing level and in a two point attitude, if one wishes to take the risk.
The cub is the same way. On gravel strips, I generally put the tailwheel down first followed by the mains in a full stall. It's cheating a bit, I think, because rather than feeling for the ground through the stick, the cue is the tailwheel running along the surface.
Not sure I'm getting your meaning here. Granted an airplane can be stalled going straight up or straight down, but, if you fly a Citabria parallel to the landing surface, holding it airborne as long as it can possibly stay airborne, the tailwheel *will* be much lower than the mains when the wing finally stops producing lift.
Guaranteed.
I own one, have spent numerous afternoons playing around with just this phenomenon.
If the wing stalls at say 16 degrees aoa and sitting on the ground on all three wheels, the wing is 12 degrees to the horizontal, your tailwheel *is* going to be lower than your mains when you stall in level flight.
AoA isn't measured with respect to the horizontal, however; AoA is measured at the wing, and includes upwash.
If the wing is done flying, the wing is done flying, whether the nose is up or down. Just as one can stall an airplane level or nose high to demonstrate it to a student, one can do the same on or near the runway, in or out of ground effect.
Granted, ground effect is actually a reduction in induced drag along with a reduction in upwash (and an attendant reduced local AoA), but the airplane will eventually pay off if held off, nose to the horizon or no.
Perhaps I don't do enough three point landings any more; most of the conventional gear flying I do is all done two-point, for some good reasons, and I usually don't full-stall them on.
