CitationCapt
STILL determined
- Dec 3, 2001
The new RNAV arrival and departure procedures at SLC have apparently caused some violations, especially within the last 10 days (WEVIC One, for example http://204.108.4.16/d-tpp/0801/00365WEVIC.PDF ). Note the speeds and altitude restrictions at various fixes. These are being disregarded and getting some crews into trouble.
In addition, here are some notes from the SLC tower that I am passing along:
Note 1
---As soon as practical after takeoff, all aircraft must accelerate to 230 kts, do not comply with speeds on the departure until given the instruction to "resume normal speed".
An instruction to "resume normal speed" does not delete speed restrictions that are contained in a
published procedure, unless specifically stated by ATC, nor does it relieve the pilot of those speed restrictions which are applicable to 14 CFR Section 91.117.]
From SLC tower
Pilots will be issued 230 knots via PDC or verbally with their clearance. They are expected to maintain that speed indefinitely until the departure controller issues something else - even if they pass a waypoint where a speed of 250 knots is authorized. (Don't worry, you won't be kept slow for long!) The speed restriction issued on the ground (230 knots) trumps all SID published speeds unless the controller assigns "resume normal speed" - in which case the pilot must fly the speed on the procedure. (That's in the AIM and in the AT handbook).
We've briefed our controllers that there will probably be some confusion among pilots with "resume normal speed" so they'll usually just assign the speed they need or say "delete speed restrictions". "Delete Speed Restrictions" allows the pilot to fly at whatever speed they –want regardless of the procedure.
Note 2
---Upon initial contact with Departure Control, state which departure you are currently flying".(Tower will also ask what your first fix is. this is expected for the first 30 days)
Note 3
---Clearance will not give you an Altitude in your clearance.
Happy flying... CC
Note 1
[AIM paragraph 4-4-12 F NOTE‑
From SLC tower
Note 2
Note 3
Happy flying... CC
