naglasair1
Active member
- Feb 1, 2007
If you are assigned to take off from 27R and you are given the clearance "cleared for takeoff 27R, turn left heading 200 degrees at the middle marker", I am assuming the "middle marker" is refering to the MM for the ILS 9L approach....or just off the far end of runway 27R. Is that correct?
did you actually get this instruction from the tower ?
This is a big misconception in ATL. They will always tell you to turn at the MM. There is even a sign at the end of the runway specifying this! But then after takeoff tower will say "Acey 4789 heading 240 contact departure".....this IS NOT a clearance to turn to heading 240. You are supposed to fly to the marker and then turn left heading 240. Once you're on the 240 heading then you are supposed to contact departure control.
In order to turn before the marker You have to hear something like "Acey 4789 fly heading 240"...or "Acey 4789 turn left heading 240". Without using the words "turn" or "fly heading" they haven't changed your original clearance which was to fly heading 272 until the middle marker.
It drives me nuts when people do that!
So, if there's a fed on my jumpseat, and I hear ATC tell us "Flight123, heading 240 contact departure" the correct action to take is to remain on my present heading and make the turn at the MM as previously cleared?
I've always intended to make the turn at the MM, but have always turned when ATC says 'heading 240'.
What if the fed happens to miss the little word "fly" or "turn" (which takes a millisecond to say), and he violates me for not following ATC instructions.
Oh well.
"heading 240 contact departure" is only an instruction for when to contact departure control. They've already told you when to turn....
Oh well.
Y'all are overthinking this.
