Amish RakeFight
Registered Loser
- Dec 28, 2005
...by the way there's also a marker sensitivity switch which should be checked along with the marker lights. Before executing the ILS, one of the checks is to ensure that each of the three markers light up. The markers are sometimes refered to as "fan markers" and only while above the marker will you hear the specific morse code identifier for each. By setting the sensitivity of the fan marker, you can adjust how long the dots and dashes of morse code go on for. A low sensitivity will allow for a shorter duration of the marker compared to the high sensitivty where the marker signal is picked up further away and sounds for a longer time as you traverse across each marker.
