QNH, QNE, QNF Altimeter Settings
  • Thread starter Thread starter Richie
  • Watchers Watchers 1
Richie
Member
I understand the definitions of:
QNH — The barometric pressure as reported by a particular station (local altimeter setting)
QNE — Pressure Altitude (29.92 or 1013.2 mb/hPa)
QFE — Altimeter setting referenced to airport field elevation (where field elevation equals zero feet)
BUT…
What do the actual letters stand for and where did they come from?
That is:
Q = ?
N = ?
H = ?
F = ?
E = ?
I poked around on Yahoo! and found the following:
"The three letter Q-codes are remnants of an extensive coding system from the days of wireless-telegraphy. There were some 200 three letter Q-codes each representing a sentence, a phrase or a question, for instance QRM "I am being interfered with". Some 30 or so of the Q-codes are still used by amateur radio / morse code enthusiasts"
Also, a link to another site which had a more extensive explanation:
Q-codes
If you run a search on "Q codes", you will get a lot of info on their use and history.
