nosehair
- Sep 22, 2003
taloft said:Of all the things to worry about during engine failure in a light single...
I was always happy if a student just trimmed for best glide and successfully setup for landing.
I can see it now...
(as airplane descends toward the ground)
CFI: "Did you set high RPM pitch?"
Student: "Is that prop in or out"
CFI: "In"
Student: "Ok it's in, but my other instructor said not to do that until doing a go around"
CFI: "Really?"
Student: "Well yeah, he said something about always training me to push prop in first, then throttle. But that was at Riddle."
CFI: "Oh I suppose that makes sense. Well just do it this way for now."
Student: "Ok"
CFI: "Hey, did you do engine restart procedure yet?"
Student: "Oh I forgot. Sorry you distracted me. Um, where should the prop be for restart."
CFI: "In"
Student: "Ok, so that's high RPM, right?"
CFI: "yeah like I just showed you"
Student: "Oh, I see why you wanted high RPM earlier. Hey, wouldn't we get better glide with low RPM?"
CFI: "yeah, there'd be less drag. Hey, you never set best glide speed. Why didn't you do that?"
Student: "I'm still adjusting this prop control knob."
CFI: "I see.. where are we going to land?"
Student: "Land? I thought we were going to do a restart?"
CFI: "Well you better get best glide."
Student: "Ok I'm finally at best glide. whew. Should I pull out the prop knob now."
CFI: "Sure, go ahead. No, wait, leave it in."
Student: "What?"
CFI: "We're going to have to go around now. See those trees? Go around!"
Student: "Ok.. So was that prop in or out now?"
........!CLASSIC!!....Excellent justification for NOT teaching the best, most efficient, taking-all-things-into-consideration, way of handling/controlling the airplane.
"Just keep it simple." "You'll confuse the student." "Why make a mountain out of a molehill."...and on and on, yada,yada,yada.
Yes! All those things apply to the BEGINNING STUDENT PILOT. The scene you describe in your scenario would be happening if you try to cram the whole thing down his throat at first, but once he has basic glide control and making the field judgement, then you add the other stuff, as he is able to do it. In the end, no student pilot should ever get certified to carry pax without full and complete control of all of the equipment that he has at his command.
....but that isn't what's happening, is it? it has become the standard to just "get by", pass the test. they don't make you "pull the prop back" on the test, do they?...so why bother....
