How can you be sure that "case break" isn't actually caused by a temporary disruption of the signal(e.g.-caused by a large aircraft taxiing across the runway) or even a permanent loss of signal due to failure of ground-based or aircraft-based equipment that hasn't yet activated the failure flag circuitry logic? Do you always do a sensitivity check to ensure that a 5º OBS course change results in a ½ scale needle deflection and a 10º OBS course change results in a full-scale needle deflection?
I think you're asking for trouble descending at "case break" and no, I don't think most people do it that way. At least not professional pilots.
Well obviously there is some thought that goes into it. C'mon, I'm not stupid. If you'd like to debate me on semantics, here you go: I descend when I have case break and I've seen that the CDI needle is actually alive and moving towards center.
On second thought, in my last post, I qualified the first paragraph with the second and third.
