Procedure turn inbound
Uncle Leo
Jerry, Hello
You are doing a full approach with a PT. The inital altitude at the IAF is 4000. The FAF crossing altitude 3000. When can you descend to 3000?
A. When PT inbound and the needle being used to define the final approach
course comes alive.
B. When the needle being used to define the final approach is centered.
C. Something else altogether?
If you have an AIM, FAR, TERPS, or some other reference I could use that too.
Uncle Leo,
If i understand your question correctly, the required approach altitude is 4000ft till the intermediate phase of the approach? If thats the case, you may descend to 3000 when established on the intermediate phase of the approach. That would be within 10 degrees of the final approach course and 10 miles (normally-or whatever distance approach chart dictates) and cleared for the approach.
Been a long time since i instructed but i would say its in the Instrument Flying Handbook for sure. Hope that helps,
ERJDCA
ERJdca said:
Uncle Leo,
ERJDCA
This is what I had always thought and when I last instructed 9 years ago it was what I taught.
I got into a debate with another pilot and I wanted to be sure I was not doing something stupid or dangerous. I will try to find the box that has my
Instrument Flying Handbook in it to verify.
course comes alive.
Let's clarify a little. I assume your speaking of an approach where the PT altitude is 4000 ft, and the first intermediate altitude is 3000 ft, right?
There are two questions, really:
1) What will keep me from hitting something hard,
and
2) what will keep me from getting a pink slip on a checkride, or an enforcement (should it come to that)
I've always considered the first question to be much more interesting, so we'll deal with that first. On a simple VOR approach with a PT, the intermediate segment protected area is splayed out away from the VOR. 10 miles from the VOR it gives 1000 ft of protection, 4 nm either side of the course, plus an additional 2 nm of diminishing protection. In the extreme example of intercepting the intermediate course 10 nm out (impossible with a PT that remains within 10 nm of the VOR, but we're looking for worst case scenario) you would get a live needle 10 degrees from the inbound course on a normal CDI (5 dots, 2 degrees per dot) at 10 miles and 10 degrees you'd be 1.7 miles off the course centerline, well within the 8 NM (4 nm either side) wide protected area. So, if you start down with a live needle, you won't hit anything, unless you've done something else wrong.
The other question is what is "correct" or legal. When may you descend to the altitude of the next segment? When you're "established" on the next segment, right? What is "established" The FAA doesn't define "established" in terms of degrees. The definition of within 10 degrees of course given by ERJdca comes from ICAO, which is not the official answer for operations within the US, so is interesting, but not particularly relevant. Instead, we have this from the Pilot Controller Glossary:
Established, To be stable or fixed on a route, route segment, altitude, heading, etc.
Now, it is quite common to begin descent upon getting a live needle, but are you established? Look at the plain english meaning of the words. Can you say that you're "stable or fixed" on a course when actually you are on a heading 45 degrees across that course?
I don't know the answer to this, and as far as I know, there is no official clarification, but I can tell you that there are some pilots who are adamant that you have to intercept the course with a centered needle before begining the descent, and there are probably examiners who feel the same way.
I'm not sure I'd want to be in the position of trying to convince an examiner that stable or fixed really means at a 45 degree angle to.
course comes alive.
Not necessarily centered, but the ICAO states within a half scale deflection. So when the needle comes inside of two and a half dots, and you are turning to the inbound course heading, it would be safe to say that you are "established". Not until then.
Consult the profile view.
course comes alive.
Most of what I'm about to type is personal experience and opinion, so take it for what it's worth...I just feel like everyone else has covered the FAA and ICAO "standards" pretty well.
I was taught that on a LOC/ILS, when the needle comes alive you can descend. Makes sense, because of how close you are when that needle comes alive...
On a VOR/GPS approach, I was taught 3/4 scale deflection...again, makes sense because of how close to center you are...
On an NDB approach, I was taught 10 degrees of the bearing...again, how close you are...
Here's my take on it.
I try to teach the students to really get "established" and "stabilized".
Before all fixes, that includes appropriate configuration, because I didn't feel like I was configured well enough to land from an ILS coming down the slide at 100kts.
So my take on it is needle centered. I want to be established. So, once the needle hits the donut or appropriate bearing, I can start down...even if that means I'm still turning toward my reference heading, I can still start down if appropriate (although, I should have been leading the turn to final so as not to blow through the course centerline). It's just a matter of being established.
Again, this is all my opinion and limited experience talking...your milage may vary.
-mini
You may descend as soon as you are on a "published segment of the approach." The gray area of this is, however, what defines a published segment of an approach. As the above poster suggests, the FAA might define it as an area within full-scale, three-quarter scale, or even less, deflection. My opinion is that if the needle is alive, you are within reception range of the navaid and thus on the segement. So, as soon as you pass the IAF and are established outbound toward the PT, you may begin the descent to the PT alititude. The Jepp profile gives you a hint by showing a line at a negative slope indicating a descent is suggested and/or appropriate. Also, keep in mind the performance of your aircraft and groundspeed. A fast descent to PT alititude might not be as necessary in a C152 as it would in, say, a G-V. In the end, as long as you are at the published altitude at the FAF (best for a stabilized descent), your descent rate and decision of when to descend is up to the PIC.
If you're way out with plenty of time to get down, then "established" is CDI in the bullseye. If your're in closer and about on profile then "established" is CDI at one-half deflection as in the ICAO definition of established. If you're in too close and high then "established" is "case break" on the CDI. If you're on a flight test use the bullseye answer if possible but if you need to descend without delay to salvage the approach, then ask the examiner what he/she thinks on this and that's the answer.
I just did a search on this topic and it still seems unresolved.
Anyone else care to contribute with more definitive FAA references?
I typically teach case break as "positive course guidance" necessary to start a descent. That's how I was always taught, and that's how I know most people do it. I guess that doesn't make it exactly "correct" as far as the FAA is concerned, but as A Squared said, you won't hit anything.
I think with the PTS now specifying a 3/4 scale deflection criteria on an instrument approach, that might be considered the "proper" time to start a descent. If you're close-in though, it may only take a couple seconds for the needle to uncase and get to 3/4 deflection anyway, so it doesn't really matter much.
The way that I personally do it is if I'm close-in or just passing a VOR that serves as the FAF, I descend when the CDI comes alive. That ensures that I'm going to actually make it down to MDA by the MAP. If I'm further out and have plenty of time, I don't like to rush. I like to stabilize the airplane on the segment, get any configuration changes done, then start the descent. All depends on where you are and how fast the approach is occuring.
It's quite odd the FAA doesn't have an official defintion for being established. Therefore I'll go with the ICAO definition of "established" as it seems like good sense. I believe I o0nce read that the AF uses this definition as well. But the difference between 3/4 and 1/2 is slim. I've always began somewhere between 3/4 and 1/2 anyways.....
ICAO - "Established"
ILS/LOC/VOR - Half scale
NDB - +/- 5 degrees
Oh, Man ! It's not possible to have an "official" definition. The Pilot makes that decision - based on the knowledge that has been displayed here.
Different situations call for different definitions of "established".
Home Base - Flat land - Very Familiar Airplane/Environment: When the vor/loc needle comes alive or the adf needle is within 15 degrees, and my heading is within 30 to 45 degress, I am comfortable being "established" and can start down. I know I am within legal TERPs criteria, and My own head is comfotable with the known surroundings.
Very Strange Unknown Terrain/Environment/Equipment, I'm gonna getthe needle off the peg a little bit to insure it is actual navigation information, not an electical hiccup, so the PTS 3/4 scale or adf 10 degrees is my basic personal tolerance, which, by the way, is 'the way' it is taught - for the worst case scenario. When you are familiar and comfortable, and still know you are well within that broad fan of protected airspace, there is nothing "illegal" about comming down much sooner. far 91-wise.
How can you be sure that "case break" isn't actually caused by a temporary disruption of the signal(e.g.-caused by a large aircraft taxiing across the runway) or even a permanent loss of signal due to failure of ground-based or aircraft-based equipment that hasn't yet activated the failure flag circuitry logic? Do you always do a sensitivity check to ensure that a 5º OBS course change results in a ½ scale needle deflection and a 10º OBS course change results in a full-scale needle deflection?
I think you're asking for trouble descending at "case break" and no, I don't think most people do it that way. At least not professional pilots.
Well obviously there is some thought that goes into it. C'mon, I'm not stupid. If you'd like to debate me on semantics, here you go: I descend when I have case break and I've seen that the CDI needle is actually alive and moving towards center.
On second thought, in my last post, I qualified the first paragraph with the second and third.
But why is it moving toward center? What if it moves toward center, you start descending, and the needle goes back to full-scale deflection OR the needle centers up and THEN the FAIL flag comes ON?
I have seen both situations more than once.
Well, in your above post you mention the sensitivity check. I actually do teach that during the VOT check. 360 with a "from" indication, then go to 350, make sure the CDI swings 10 degrees. Then go to 010, make sure it swings 10 degrees. Do the same with the "to" indication.
I'll readily admit that I don't always do a sensitivity check, though. If one had been done recently with the VOT check, then I tend to skip it assuming we're going in VMC.
How long are you gonna keep dancing around the questions?
Alright, we're done. Why you decided to single me out is beyond me, considering my answers were really no different than just about everyone else in the thread. Have a good one.
I'm sorry if you think I singled you out and am picking on you. That was not my intention.
I just think you are not only practicing but are teaching others a practice that, in the right circumstances, could be dangerous. I tried to ask questions that would lead you and other readers to consider what could go wrong. Of course, things do tend to go wrong at the worst possible moment(e.g.-when cockpit workload goes through the overhead when the weather is crappy, fuel is tight and ATC decides to "slam dunk" you.)
I do hope you at least think about the points I tried to make.
Alright, sorry if I overreacted, but you have to see that your posts have come off as rather challenging and dismissive. If we can have a good discussion on this topic, great, I like to learn new things.
But to be perfectly honest, I don't really understand your last question. Is the needle coming in normally, then all of a sudden it fails? If it does that and I don't have any other course guidance (i.e. maybe a ground station failure), then I probably make a bolt for MSA while turning to fly the inbound heading and picking a new approach to fly. Makes sense to me, but I'm open to suggestions on that one.
What's the other situation that it could be? Being off course and getting erroneous CDI movement?
Well, to neutralize this a bit, let's say that the needle begins to swing in, but rather than at case break, we wait until 1/4 to center until we begin the descent.
It is just as conceivable that something could still be interfering with the signal casuing the needle to swing towards center even if you wait until it comes in just as in the case break example.
