EASY EASY
Not meant to be a slam skydork (whoa horseee!). Just a reply. I personally have over 2500 hours in T-tail aircraft (including Seminole) operating a fair amount of that time off grass. There is nothing in the POH for the Seminole that prohibits grass take offs so therefore the procedure would be the same as with any other T-tail.....ie don't start with full back pressure on the yoke as you do with a conventional tail. Simply allow the aircraft to accelerate to a speed where the T-tail will "fly" then rotate from the surface and remain in ground efect until the appropriate airspeed.
