primary inst while on Glide slope?
I was taught to use the VSI and DG. Nials those two and you'll always keep the needles pegged. This also keeps you from chaisng the LOC and GS. I'm sure everyone has their own opinion.
Provided your airspeed doesn't change, you are correct.
It's all about control and performance, forget that primary and secondary **CENSORED****CENSORED****CENSORED****CENSORED**.
Set an attitude with the attitude indicator, trim, crosscheck and adjust.
For the glide set your attitude and use the VSI to see what performance you're getting, if you're high reset your attitude for a greater descent rate.
I use the airspeed as my performance gauge for power on the ILS.
mmmdonut said:
Ground speed.
(And what the hell is with the "The message you have entered is too short. Please lengthen your message to at least 5 characters?" So much for conserving bandwidth with my wink instead of this long drawn out question.)
I personally believe that all this Primary stuff is BS...do what feels right...keep your scan but do your own thing...
I disagree, FlyinTim.
I've spent more hours than I can recall watching students try to have some amount of stable & precise flight controlling the a/c in response to either LOC/GS indications or VSI (non-IVSI)/ASI/ALT. There IS a difference in effect if the pilot's inputs are held until a performance or navigation display responds vs. a pilot's input against the AI/AH then waits for noticeable change, assess the rate of response in relation to the nav/performance instruments & reiterates.
So, when someone asks about primary instruments my first question is 'In relation to what? Control of the aircraft or measurement of performance WRT to a desired flight path?'
If control is the point then the AI/AH + power indicator(s) are primary. If measurement WRT to flight path then one could argue that the primary instrument is the performance instrument that most readily defines the desired plane(s) of the flight path however this only measures performance not control.
If you're looking to maintain the centerline of the LOC and GS, wouldn't your primary instrument be the HSI or VOR/LOC/GS?
Using your nav instruments keeps your needles centered...everything else is supporting?
IE.
LOC/GS = Primary for Bank and Pitch
ASI = Primary for Power
DG/AI = Supporting for Bank
ALT/VSI/AI = Supporting for Pitch
Tach/MAP Gage = Supporting for Power
Perhaps I'm making this too simple...to me what makes sense is on an ILS you maintain the GS and LOC in the center. To do that, you "fly the needles" all the way to DH.
Just an opinion....probably wrong...
Eyeore has left the building...
-mini
not be be a wise-a$$, but my primary instrument on the ILS IS the localizor and GS needles
follow those and everything else works out, hell you even are at VREF at 50 feet and land at the 1000 foot markings
can't ask for much more than that
(above is based on airplane being properyly configured per POH/etc during approach)
I was going to say that the primary instrument on the ILS is the flight director. ;)
'Sled
It's a form of linked chain concept.
If you, say, pitch the a/c to correct a GS error using the GS to tell you when to stop pitching then you'll overcorrect, resulting in flying through the GS and a mirror image of the problem. This yo-yo-ing results in the GS being seen -momentarilly - as the a/c passes from one side to another. As a/c speeds, mass & inertia increase, and proximity to the transmitter decreases then the pilot responses will not be adequate to constrain the flight path within the required tolerances.
So, the next step back from the direct reading instrument (the GS display), is to establish a nominal rate of descent for the rate of closure that will match the GS angle. At best the a/c will exactly parallel the GS (if the descent started whilst on the GS), at worst the descent will diverge at a rate inversely proportional to the distance from the transmitter. Of course this assumes the ROD is exactly correct. If the descent rate is incorrect then it will result in either closing with the GS (yay!) or diverging from it (boo, hiss).
Trouble is that pitching to establish a descent rate by reference to a normal VSI results in a similar GS display ie yo-yo-ing.
What next? Use the AI/AH to set a constant pitch angle. If power is unchanged then ROD is roughly linearly proportional to pitch attitude, at least close enough over small changes to be useful. Now the key becomes 'check the GP to determine location WRT to the GS, check VSI to determine ROD WRT a previously calculated approx. 'ideal' ROD --> adjust pitch attitude by a small amount WRT to the AI/AH & wait for a stabilised (or nearly stabilised) new ROD in the appropriate sense --> wait for change of position WRT to the GS to be indicated on the GS display. If the rate of change is insufficient then reiterate.
NB: At some point in this process will be found a pitch attitude that very nearly 'freezes' the GS needle. Remember that attitude for when the GS is eventually regained then use it as the subsequent baseline reference point.
This results in a far more stable & controlled GS than the other scenarios I mentioned.
The principle in the above GS example is no different to establishing a CDI intercept. I don't think anyone would advocate rolling the a/c until they saw the CDI move? Or, one step back from that, roll the a/c until they saw the HDG reach the desired point? Try that a 180deg required HDG change... :D. Instead we all roll the a/c by referencing the AoB on the AI/AH, holding the desired AoB while the a/c turns, then holding the new heading while waiting for the CDI to move etc.
So... in my view the AI/AH is the primary instrument(s) along with power & the ball.
Sorry if this gets a bit basic, but I found it difficult to explain my point without resorting to first principles.
IE.
-mini
mini has it!
When this is practiced, the initial overcontrolling will eventually stop. You will learn to percieve the slightest movement of the needles and make an ever-so-slight control input to correct so that the needles don't get even a dot away.
The trouble with setting an attitude and power setting and don't chase the needles is, that it works fine with little or no wind or turbulance. But with strong crosswinds or large vertical movements, as in thunderstorms, the "primary instrument" technique will always work. Setting an attitude won't.
Holy Crap, Tin!
Loc, G/S, Hdg, Alt, A/S, Repeat until minimums.......small corrections as necessary.
Just fly the freakin thing!!! Works in a 140 as well as a 757!
It ain't rocket science, each student needs to find what works for him/her.
I had a kid one time that got some screwy formula from a retired Air Force Col. that was teaching ground school, He was doing great until he decided to try to use that formula for decent FPM , intercept angle, yadda, yadda, yadda, Once I got him to forget all that crap and just fly the airplane he could nail an ILS no problem!
2¢:
If the question is asking "According to official FAA doctrine, under the 'primary/supporting' method of flight instrument interpretation..." the answer is the VSI. Flying the glideslope is treated as a constant rate descent.
If we're talking about the in-flight techniques that put that theory into practice, I'll leave the argument about the "one true way" to the same people who argue about pitch and power.
mmm...Midlife, do you read that anywhere specific in the FAA-H-8083 Instrument Flying Handbook?, or any other FAA publication?; that flying the glideslope is treated as a constant rate descent??
Trouble is, the FAA Handbook talks about the primary/supporting method in the context of basic flight instrument scan. I can't see where they flow that scan into the nav instruments, which essentially become primary when you consider the basic statement in the bottom right corner of page 4-3: "The instruments that provide the most pertinent and essential information will be refered to as primary instruments."
Flying the glideslope as if it were a constant rate descent won't work - because it's not. Oh, you might have a day or two once or twice a year when there's a dead calm and you can "set it and forget it" on the glideslope. If it wern't for wind and slight turbulance, these things would be as easy to fly as drivin' a car.
But wind, my friend, is the great equalizer.
The glidesope needle tells you what to do with the VSI.
When you are trying to hold a constant altitude, the Altimeter tells you what to do with the VSI, therefore, the Altimeter is the Primary instrument for pitch in level flight, because the altimeter tells you what to do with pitch. My "technique" of controlling that pitch is with the VSI, but that is my "technique". Others use the attitude indicator, that is thier "technique", but we all are using the Altimeter to tell us what to do with the pitch.
When on the glideslope, we are using the glideslope needle to tell us what to do with pitch, then using the VSI to control that pitch, or, depending on personal "technique", using the needle itself to gage pitch input.
I know you know all this, but my original question is, have you found any FAA pub that even talks about the "techniques" of localizer or glideslope capture and/or navigation?
No, I haven't seen anything official.
But what you say is exactly the point. The "primary supporting" theory of instrument interpretation is a =flight= instrument methodology for aircraft control - how do we verify that the airplane is doing what it's supposed to do - in this case descend at both a desired airspeed and at a desired (although changeable) decent rate. It deals exclusively with airspeed control, not navigation.
In the glide slope context, yes, we're following the needle. But we also know that following needles leads to overcorrection. If we need to correct for lateral drift, we turn a specific number of degrees. Similarly, if the glide slope needle is low, we don't just pull power to idle (well, some of us probably do ;) ) we make a power and pitch change that adjusts our descent rate to something specific. That's rate descent control (or at least one of the reasons we focus on rate control in early attitude instrument training) . It's sort of a traditional separation of aviate and navigate.
Does anyone know of ANY pub' that covers, specifically, ILS instrument scan? I found with students that it really depends on the individual. I agree with Nosehair. Just as you would consider the Altimeter and HI to be primary in level flight, the needles now become your primary focus when on the ILS.
Glideslope is the most dynamic and is checked at the needle.... adjusted at the AI..... and maintained at the VSI, in that order. Course is checked at the needle and adjusted at the HI. Now, that is what works for me. I'm not saying it's the be-all end-all because, as I've said, everyone seems to develop a comfortable scan.
The FAA a.c. does not specifically cover proper scan on the ILS they do state THIS in the first few pages of the Attitude Inst. Flying section:
......As a beginner, you may cross-check rapidly, looking at the instruments without knowing exactly what you are looking for.............As proficiency increases, you scan primarily from habit, suiting your scanning rate and sequence to the demands of the flight situation.....
