TEXAN AVIATOR
Bewbies
- Oct 21, 2002
The body of the ASRS report may not be used by the FAA for enforcement purposes, but the title line of the report, the form you get back, can. It is not protected.
avbug said:On the question of being busted while flying incognito...
When I was flying air attack, one of my duties was escorting aircraft out of TFR's over fires. Aircraft would bust the TFR to rubberneck the fire, putting a lot of folks in jeopardy, and shutting down fire operations until the offending aircraft was out of the airspace. We regularly intercepted these aircraft and escorted them out of the TFR.
The aircraft registration was noted and passed on for enforcement action. In some cases the pilots were met at their destination after being tracked by request.
The same will certainly happen in other types of temporary airspace, too. I've seen it happen in Class B, as well.
Your best bet is to file the report; don't simply pretend it didn't happen; protect yourself by filing the report.
A Squared said:ORFlyer,
here's a link to an NTSB case where the NASA return receipt was used in the enforcement NTSB Order
avbug said:As for tracking the aircraft...simply getting your aircraft number isn't enough. Many times the FAA will approach a pilot and idenfity the aircraft as having been doing something illegal...buzzing, whatever. It's the pilot that hangs himself when he puts himself in the airplane. If the pilot is caught in the airplane, that's one thing...but if the FAA has an aircraft number...they have a number. Not a pilot. It's up to you to put yourself in that airplane for the FAA; it's up to you to convict yourself.
Under Administrative law, you're convicted merely by suggestion. However, where you get your say is on appeal. If you have already stipulated that you were the one flying, you've already torpedoed your appeal. Instead, if you have kept quiet and filed your report, you may get violated. In the meantime, under the protection of the ASRS, you don't serve out the violation, and you can get the violation reversed on appeal...remember, it's during the appeal that the FAA must show that you were in the aircraft. If they can't do that, chances are that you will win...unless you did something foolish to give them the evidence to convict you in appeal.
The choice is yours.
