flya380 said:Hi,
Are some of you using the plantronics MS 50 in the CRJ/ what do you think of it?
flya380 said:Hi,
Bizjet said:I have been using the same MS 50 T30 for over 20 years with no failures. It has a round junction box just where the cord splits into two plugs one for the mike and the other for the sound. There is a jumper wire in the box that can be moved to different pins to change the db by + or - 10 db. This tailors it to work with most aircraft systems. It is comfortable and durable and has been produced for over 35 years. Plantronics will totally refurbish the unit for about $60 dollars for as long as you own the headset.
ERfly said:What does it change the DB of? The sensitivity of the mic or the volume of the speaker?
