NoPlaneNoGain
- Nov 26, 2001
Glad to hear that you made it down safely. Good job handling the situation.
I once lost an intake valve on a Navajo when I was a freight dog. I had sprayed oil all over the left cowling and had shut the engine down before it did itself. Once safely on the ground I first inspected the oil cap just to make sure it was on tight, and it was, thank God! The local mechanic pull the cowling off and we found a hole that the valve had been driven through causing a loss of oil.
Anyway, it sounds your situation might be a rod or valve problem.
