Final appr checks: Reds, Blues, Greens or PUFF: Power, Pitch, Undercarriage, Flaps, Fuel & Fuel Pumps.....
Before commencing the descent I adjust the mixtures too, in the cruise the FF on the 402 is around 90 - 95 lbs/hour, for the descent I set it 100.
I richen then mixture on finals, maybe not full rich, but richer than operation at flightlevel anyway. Climb setting after take-off is 120, so thats a good refrence for me to aim at.
As for the props....this is a bit sticky as it would be heavily biased per personal preference. Top of Green at least, the last little bit that makes the most noise...um, I prefer to push the props full fine, just in case a go-around is needed. You might not alway have time to push all the levers forward, if your hands are on the throttles levers.
With a patient in back (we do medevacs), and stable approach with good conditions, I sometimes leave the props TOG, but usually they go full fine.
right, tell you guys what...I have always done the take-off in the C402 with the mixtures full rich....next one I do ( did 4 today, should have remembered!) I'll lean it out a bit and check the difference.....
