My CubCrafters cc363i (Lycoming IO-360) has automotive spark plugs using a 18mm to 14mm adapter. I've been doing my compression checks and got 80/80 and then this year decided to get a borescope and let my maintenance shop do compression testing. I was surprised at first that they removed the adapter which I had planned to never remove, not a big deal, but they got 76/80. This makes me wonder if compression checks are different at 14mm vs 18mm? I also realize compression testing is not a science, the accuracy seems suspect at times.
