Lear70
JAFFO
- Oct 17, 2003
You're absolutely right about the training, although they've started incorporating it into recurrent PT sims.LJDRVR said:Lear 70,
One of the real tragedies here is that line pilots are not taught how much nose pitch attitude will be required for a relight on your average turbofan-powered jet with all engines flamed out. Core-lock or not, those guys never pushed anywhere enough to get those motors rotating. I don't know what the numbers are for the CRJ, but most twin rear mounted engined jets require in the neighborhood of 25-30 degrees for sufficient airflow.
In the CRJ it's approximately 12-15 degrees nose-down to get those speeds, this aircraft is pretty slick aerodynamically. You're absolutely right however, they never reached the speed (although they got pretty close during the first part of the descent).
Either way, the last restart they tried to do was at low altitude, and it certainly should have rotated at least SOME... but it didn't. Absolutely flatline zero.
