On the pre-class written test regarding the PA32 systems, we are asked about the prop governor. If you lose oil pressure, will it go to high/low RPM, what about high/low pitch. I'm going crazy with the AFM trying to find anything that says, nothing in Sections 1, 7, 8 or 9.
1) anywhere else I should be looking for this answer?
2) In absence of any evidence to the contrary, I'm assuming it works like the governor on all other complex singles that I've flown. IE the spring/nitro charge drives the prop toward the low pitch/high RPM stop, and oil pressure moves it towards the high pitch/low RPM stop; therefore loss of oil=high RPM/low pitch.
Can anyone confirm/deny this? Thanks.
Scott
Scott
