Rick James
- Mar 7, 2005
Our Piaggio II is heavier and has more drag than our I, so that may be why the speed difference is nil.The B engines should hold max torque to a higher alt,
for a given temp value(785?) which will give you a higher TAS. Another thing I have found is once you are at an altitude that you are limited by temp, in cruise bring the props back to 1870. I generally see about 5-7 kts increase in IAS. This doesn't work once above fl370 though. I have been experimenting quite a bit during 2000 hrs in the P180.
Are you saying that you bring the props back to 1870 to increase speed?
Though I only have around 1k hours of time in Piaggios, I still think my observations have merit.
