Blowby IS increased, anytime you put more pressure into a cylinder you will inevitably get more gases that pass by the cylinder rings (more blowby), they teach you that in basic auto shop!
Apparently they didn't teach you that in A&P school...not a mechanic are you? (I am). Why, because it's not true. Nice try though. You're operating your aircraft in a turbonormalized condition, operating them only to sea level pressure...you're not inceasing wear in anything. Not even remotely close.
Also the fact that you say the 402 is turbo normalized leads me to believe you don't know a dang thing about the 402. They are not turbo normalized, 30 inches is just the cruise setting that we use, you can use 32inches and 2300rpm and they go up to 34.5 inches and 2700rpm for max power in the B models and 39.5/ 2700 in the C, BUT the C DOES have a different engine, still a 520 but a different model, where as the B's use the same model 520.
You're operating it in a turbonormalized state, not exceeding sea level pressures; anything more that is within limits of the engine is irrelevant, because you're not opertating it under those conditions. THINK!
As youstated, diffrent engine models, and therefore your comparison is no good. Different baffles, different inductions, different aircraft...you simply can't turn an apple into an orange. Nice try, though.
The inlets are the same, the baffling is different and the outflow are different to allow MORE cooling on the 402, which should make the engine last longer.
That's a very simplistic, but uneducated and wrong way to look at it, but once more, nice try. Too much cooling is just as bad as too little, but both issues are irrelevant. How the engine is cooled, where, and when is much more important, just as is peak oil temperatures...your oil breaks down thermally long before it's affected by contaminants...which accounts partially for the color, along with contaminants picked up and in suspension. Simply because one has more cooling available doesn't mean it lasts longer or is in a better state. You need to do a little study before you pursue that one.
In any case, that doesn't address the operating parameters, nor the warm-up, cool down, or other facets of operation that most operators neglect. You are giving the turbo a five minute cool down after landing, right?
Also color of oil is not irrelevant, if your oil is dark you have more particulates in it, which will break the oil down chemically or cause it to form sludge blocking oil passages, again basic auto shop here, nothing earth shattering.
Aaah, again, wrong. You really should study a little on this, before you pursue it. Next you'll be telling us you can tell the condition of the oil by it's color, or that the color has any meaning at all (it does not). Not such a nice try. READ!
If blowby and oil color was meaningless and irrelevant then we wouldn't have systems to remove blowby or change our oil. Why do you think you can drive 100,000 miles on your transmission fluid (which is just oil) but only 3,000 on your engine oil? It's because blowby breaks the oil down, since there's no blowby gases in the transmission the oil doesn't break down.
Again, very wrong...more than apples to oranges there...no comparison between circulating an operating fluid through a non-combustion transmission, an entirely different chemical formulation from engine oil, and engine oil in an internal combustion engine. Why not compare toe nail polish to beer? To what systems are you referring to remove "blow by?" Are you talking about crank case breathers? You understand that there's a lot more going on in that crank than merely venting for "blow by," and that the breather is necessary even if there isn't any "blow by?" You do get that, right? You're aware that some companies had systems for many years which pumped raw fuel into the oil after shutdown and before start as part of the oil dilution system...intentionally putting combustion products into the fuel, right?
You also keep referring to the fact that when you cruise in the 402 at 30 inches it's the same as a N/A engine at sea level. This is true, but a N/A engine is only going to be at that pressure for a few seconds because even at full throttle the instant you break ground the pressure will drop.
Actually no. A properly designed induction in a normally aspirated engine will experience a ram air recovery and even ram air rise with the ram effect of the propeller and forward airspeed...getting thirty inches or more is not uncommon in normally aspirated airplanes close to sea level.
No N/A engines cruise anywhere near 30inches and in most cases you don't even get 30inces on takeoff since the air is restricted slightly through the induction system and filter. Also I still don't understand your rationalization that an engine not running on the ramp showing 30in is the same as a running engine at any MP, that just doesn't make any sense.
One surely can get full barometric pressure in a normally aspirated engine...especially at sea level. As for the explaination about an engine at rest at sea level...you assert that pressure damages engines, and the terrible, awe inspiring tubonormalized setting of 30 inches of manifold pressure is causing excess wear in your engine...no it's not, and that's no greater value than you'll see on the gauge when the airplane sits for extended periods doing absolutely nothing. The manifold pressure you're seeing on the gauge is irrelevant. You get that part, right?
Why because we're running higher pressure through them, which produces more power, which produces more heat, more blowby and just generally causes things to wear out alittle faster over the long term.
If the oil is changed regularly, then the issue of blow by is irrelevant. Again, irrelevant. Once more, sing it together, irrelevant. If you are seeing blow by to the degree that it's causing engine damage or wear, then you have some serious mainainenance faults and need to look at doing better inspections. Even if that's happening, it's not going to cause the engine to wear out faster. Not happening.
If the engine is operated within temperature limits, you're not wearing anything out any faster.
Your comments do indicate why the FAA mechanic certificate takes lot more doing, and is a lot more complicated and involved than any pilot certificate...and why you need one before you put your fingers in something you don't understand. Do a little research on your claims here, then get back to us with your new found knowledge. I'm sure it will be enlightening for us all.
