Oversquare ops
unreal
I've noticed that the old rule of "never operate with a higher MP than RPM divided by a hundred" is still alive and well, both at my current school, and apparently at others as evidenced by the thread about power reductions after takeoff.
This never made a whole lot of sense to me to begin with, simply because turbocharged engines are almost always operated oversquare, and normally-aspirated engines often takeoff oversquare, and even have cruise power settings that allow for oversquare operations. Now, I have two questions:
1) Are turbocharged engines typically built to handle a higher loading compared to normally-aspirated engines, or is the oversquare fear on NA engines just a kickback to that "old rule"?
2) On a typical NA engine found a light aircraft (we'll say anything up to an IO-550), does operating the engine oversquare even really do anything that'll cause a reduction in service life? My understanding is that the old oversquare rule had more to do with old radials than anything else.
Just curious about all of this. I've found that my school is chock full of "old rules" that someone came up with years ago and nobody ever questioned. Unfortunately a lot of that has seeped into my own training, so it'd be nice to get to the bottom of this as to get out some of those bugs.
It amazes me, too. You have two entirely separate readings, in different units, measuring different things. Why in the world would they be related? What if you measured centimeters of mercury instead of inches? What if the prop tach were in "Thousands of revs per hour" instead of "Hundreds of revs per minute"? 2400 would all of a sudden be 144, but would be the same speed. Would that mean I could then go to 144 centimeters of mercury? What about 144 inches?
There's only one "guideline" for operating an engine, and it's found in the operating handbook for it. I'm not sure where that "oversquare" idea originated, but I'd venture that very few engine models are actually restricted that way.
This never made a whole lot of sense to me to begin with...
Go with your gut! Because you're absolutely right.
Depends entirely on the specific engine. Some simply use turbocharging to maintain sea-level manifold pressure to a higher altitude. Others allow pressures higher than sea-level pressure, and of course that would require a sturdier engine (or shorter engine life).
Quite the opposite, actually. Assuming you stay within the pressure limits of the engine, let's say you're presented with two possible power settings for a given percent of power: One is a higher-RPM, lower-MP setting, and one is lower-RPM, higher-MP. I'd contend that the more revolutions you put on that engine, the more you're wearing it out. Every time it goes around, each valve is getting cycled, each bearing is wearing, etc. I'd go for the lower-RPM setting for the same reason I do it in my car by going to the highest gear possible: a quieter airplane (inside and out), less engine wear, and better fuel economy because of reduced engine friction.
It's another bit of "knowledge" that was never correct. Take the F4U Corsair's R2800 engine: Rated-power climb was 42.5" of manifold pressure on 2600RPM.
That's the beauty of teaching people to fly: You're motivated to find real answers, not conjecture, and you'll often find that the things you thought were true--like the "oversquare" myth--really aren't. If someone refuses to believe that it's a myth, ask them to show you in the aircraft manual, a flight training manual, or any kind of definitive source. I'll bet you they can't.
First off, there are two kinds of turbocharged engines on airplanes.
Turbonormalized engines with automatic wastegate turbos should maintain no more than 31" no mater what you do with the throttle. In this instlation the turbo does nothing for you at sea level. It gradually adds in boost to offset the lower pressure as you gain altitude.
Turbocharged engines with fixed wastegate turbos will have a maximum allowable MAP, useually about 40". If you add full throttle at sea level you will overboost it and poossibly cause a seal to blow on the intake manifold. The engines are built to handle the added pressure, therefore as long as you don't exceed the limits, you're OK.
Operate your engine by the figures in the POH and you'll be fine. 2100/23" is no problem on most engines. The slower speed may actually reduce vibrations which wear on your accesories. All the old radials ran oversquare, some racers at Reno run about 2500 RPM and 70" MAP!
Now, don't get stupid. It's apropeller not a paddelwheel! 1800/29" on most engines is not published in the operating handbook, and will proabaly break soemthing eventually.
I too learned most of these false myths about piston engines as I was training at a large flight school with glossy ads in Flying. My time at A&P school cured quite a few of them.
Read the articles from Avweb by John Deakin.
http://www.avweb.com/news/pelican/list.html
Best tutorial on engine operation I have seen.
undersquare bad
On round engines, R-1820's etc. Oversquare ops are not a big deal if done within the limits specified for the RPM and MAP. Used to launch off the boat in the C1A, no cat 59.5" 2800 RPM. But on round engines undersquare is to avoided if at all possible. Undersqaure causes the prop to drive the engine and reverses the loads throughout the drive gears and increases the likely hood of premature failure.
Open a piston POH. Look at the power setting table. Then look at the engine manufacturer's operating tips on its web site (Lycoming generally recommends the highest MP and lowest RPM combination in the table for smooth operation).
Correct responses on all accounts. Oversquare operation is a myth.
You asked if there's a difference between a boosted engine and one that isn't, with respect to construction...in most cases, no. The same engine that's normally aspirated vs. one that's boosted (turbocharged, supercharged, turbonormalized, turbocompounded, whatever) usually involves the same part numbers. For example, an O-520, IO-520, and TSIO-520 may use the same cylinder part numbers. Same construction, same material, same workmanship...but for different engine designations. This isn't always the case, and you need to refer to the specific engine...but the truth is that blown engines (boosted) often use the same parts that normally aspirated engines do. The increase in pressure isn't so much stress on parts due to pressure, but due to head, and decreases the margin approaching detonation in cylinders...which tends to do more internal damage than external...which is part of the reason that in many cases the same cylinders are used for both engines.
If you think about it, a normally aspirated engine operating at sea level will be showing nearly thirty inches of manifold pressure before any ram air rise at high power settings. Your RPM is typically 2500 to 2700 rpm at the prop, which means your takeoff manifold pressure is already "oversquare."
As was previously stated, you need to look at your manufacturers power tables and limitations to determine what's applicable to your aircraft, and you should always stay within those limitations. Many more issues apply to a power setting than oversquare...oversquare is a non-existant theory without any backing, which has been passed down from instructor to student in what I like to call the heritage of inexperience...one statement of ignorance passed from an inexperienced instructor who was told it by another inexperienced instructor who was told it by another inexperienced instructor, ad nauseum.
Other issues affecting takeoff power setting are the compression ratio, propeller limitations, type of drive and gearing, crank shaft design, harmonic issues, and a host of other reasons that a given limitation or power combination is provided by the manufacturer. The manufacturer has subjected the engine to very expensive and extensive testing...the manufacturer does not explain why the limitations apply in most cases, but you should always abide by the power schedules, fuel flows, temperatures, RPM's, and other criteria established by the manufacturer.
Pilotyip touched on the issue of undersquare operations...operating undersquare, per se, won't necessarily cause harm to your engine. But operating undertorque can...the potential for damage is greater in some engines than others. As a general policy, operating when the propeller is driving the engine isn't a good policy and it's a matter of poor airmanship. You'll find some in aviation who disagree with this...Avweb publishes a list of "Aviation Myths" which include this among others. I disagree, and I've had discussions about it with the author and many others...the particular type of engine is a big consideration, but even simple direct drive engines as a rule shouldn't be descended for prolonged periods of time at idle at high airspeeds, when the prop ends up driving the engine.
"Undersquare" operation is okay, to a point...only when you hit a point of zero torque when the engine isn't driving the prop, can you run into potential problems. In piston engines, and reduced power settings, thermal issues can become a concern, which is another reason to avoid prolonged operations at reduced power, too.
Operation "oversquare" isn't so much about overboosting anything or lifting heads, but more about detonation...but again, the "oversquare" issue is a mute point...nonexistant becuse it presumes a relationship or rule which simply does not exist. As always, refer to the manufacturer recommendations, proceedures, schedules, and limitations.
I'm trying to understand, since I'm very new to all of this. Is the zero torque issue a problem because everything is sort of "floating", e.g. the prop isn't driving the engine and vice versa?
And in your second sentence, are you referring to "shock cooling", or something along those lines?
This depends on the engine. Geared engines vs. non geared engines, size, drive, make up etc. Floating isn't really a correct analogy, though backlash, especially in geartrains, can be an issue. Torque is reduced or reversed, with a reverse loading on bearing journals, crankshafts, etc. Pressure, wear, and fit is brought to bear opposite and out of sync in gear teeth, and on bearing surfaces. (Some argue this, saying the engine is still turning in the same direction and therefore this cannot be...but they're incorrect).
Thermal issues can include shock cooling, though that discussion is beyond the scope of this thread. Shock cooling is a controversial subject. A primary means of temperature control and cooling in an aircooled engine is airflow, as well as power management (to include power settings, engine RPM [and subsequently propeller RPM], mixture setting, etc).
Suffice it to say that one should treat one's engine as though one's life depends upon it, becasue surely it can do. The ignorance with which engines are often treated, as a function of the heritage of inexperience (particularly in the training arena) means that many pilots are scarcely aware of the proper operation of the powerplants under their control...a lot of abuse takes place. One can get away with it in some powerplants, but not in others. Fostering good habits is best done when both taught properly, and practiced properly, and good airmanship dictates that one properly treat one's equipment, even when the equipment is forgiving enough that one may get away with poor behaviors.
I have done a little research on the topic. As it turns out, 25" - 2500RPM is about 75% on most IO type engines, which is recommended for climb in many A/C. 23" - 2300rpm is about 65%, which is good for cruise in many A/C. I would imagine many operators told there students to operate the engines at those settings to 1. Give them a starting point & 2. Help control wear and abuse.
In short, operating over square is a myth. One should always consult the POH to find the proper power setting. In general, pick the percent power that is appropriate for the operation (high speed cruise/climb power - 75%, reduced wear/normal cruise - 65%, extended endurance - 55%, holding power - 45%, ect.) I can't stress how general that all is. The C402B (large bore, turbo charged) recommends no more than 70% power where the C172R can be run at 80%. Then use the combination of RPM/MP that gives that percent power. In general, higher RPMs will give you higher CHTs (increased friction heating) and higher fuel burns. I tend to use the higher MPs with 2300rpm w/ most normally asperated engines to get the best combination of KTAS/engine wear/fuel burn as opposed to incresing the RPMs to 2400-2500 rpm, although according to most POHs either is allowed. Of course this will all vary slightly with specific atmospheric conditions and altitudes.
Again, I can't stress how general that all is and how important it is to read both the A/C and engine POHs and to read, understand and follow the power charts and recommended procedures. Also remember that many older A/C have STC's and the books may not reflect what is actually in the A/C, for example, older C172s w/ O-360 180hp Lycomings or BE58s w/ IO-550s. But that's another kettle of fish...
What aircraft POH recommends you climb at 75%? Always climb at max continuous at the recommended airspeed from the POH.
If I remember correctly, the seminole POH called for 25" and 2500 RPM for climb and the baron called for 2500 rpm (full throttle) for the climb. IIRC.
Most aircraft have a variety of climb schedules, just as they have cruise schedules. Climbing at full power may or may not be necessary...again, according to your mission. If you're doing pattern work, for example, carrying full power to one thousand feet or fifteen hundred feet may not be reasonable...you may be making a power reduction right after takeoff just to keep it slow and keep the rate of climb reasonable...all depends what you're doing.
The subject of operating at reduced power has been mentioned as a way of saving wear on the engine. Operating at a reduced manifold pressure does not necessarily save anything...reducing RPM does, but sometimes at other costs...and may still result in more wear. You need to look at your specific mission--what you're hoping to accomplish with the aircraft on a specific flight--to determine what schedules you want to fly.
Takeoff thrust or power is not necessarily the same as climb thrust or power. Use what you need, and what you have planned. Using maximum takeoff power when it's not needed is just as ridiculous as not using enough when you need more. Use what you need.
This is 100% correct
This is incorrect with the respect to pressure issues. At a given manifold pressure, higher RPM's are easier on the engine. However, pressures only come into play at higher MP settings. A normal piston aircraft engine (non FADEC) has fixed timing. The cylinder usually fires about 20 to 25 degrees prior to the piston reaching top dead center. The mixture does not just explode, it burns with a flame front progressing from the plug to the center of the cylinder. Ideally, peak pressures within the cylinder happen as the piston is travelling back down, producing optimum mechanical advantage (peak power). If the piston is travelling slower (slower RPM), then the pressures are higher because the mixture is firing closer to top dead center, meaning that it has to overcome the position of the connecting rod, producing more pressure within the cylinder (bad) and less power.
Try investigating Charles Lidburgh's efforts in the western Pacific in WWII.
He played a major part in teaching American pilots how to fly the P-38!
Oversquare was what he preached, and he increased the range of the aircraft by almost twice, without damaging the engines. Good story, really!
Its a bunch of crap.....I have a Cessna 172 that is 1956, it just happens to have a manifold pressure guage. (don't know why) guess what you will be running over square until you reach about 5000 msl. Follow the POH, otherwise people are trying to reengineer or make up procedures that really have no basis. Its pretty dumb, yes most turbo a/c cruise over squared. Does'nt seem to TEAR them apart. The other thing that kills me is the BIG hurry to get the power pulled back, just relax pull it back lesiurely at 1000 agl or so, no big deal or hurry. Geez.
Actually running high pressures do take their toll on turbo charged engines. I fly 310's and 402's they both use identical engines, Continental IO-520's. But the 402 is turbocharged and always cruses over square. The 310's run to 2200hr TBO, and the 402's only get 1800hr TBO. On the 310 you can't tell the difference between a 200hr engine and a 2200hr engine. On the 402 you can feel her getting tired when it's getting near TBO, CHT's start running high, oil turns black quickly, uses more oil, has less power, and use more fuel. So running higher pressures definitely cause more wear.
Higher pressures don't cause more wear. More heat causes more wear, higher RPM causes more wear, inconsistant operation, heating and cooing differences...these cause more wear. The engine doesn't know, and can't tell about cylinder pressure...the fuel air mixture knows about it, and responds with detontion under very specific circumstances...which does reduce engine life. But higher pressures of their own accord do not reduce engine life.
Two entirely different airplanes. Same manufacturer of the engine, but not the same engine. Not the same fuel system, delivery system, operating parameters, cooling, induction..different engines. Apples to oranges. Poor comparison, and one cannot draw conclusions with any degree of accuracy as you've done there.
Nice try, though.
Nice try, though.
Your right higher heat does cause more wear. With higher cylinder pressures you will get higher temps, you'll also get more blowby which breakes down the oil faster. The planes while they may look entirely differant, they're not, they share many systems and from the wing root out they are identical to a turbo 310. And actually they are the same engine, same fuel system, and same fuel delivery, induction and cooling are the only differences. The 402 is turbo charged, and has additional cooling via cowl flaps. The 310 is generally operated at 2300rpm and 23 inches MP, the 402 is run at 2300rpm and 30 inches of MP. This isn't apples to oranges, it doesn't get any closer than this.
Again, nice try. Two entirely different airplanes. Make very small changes, such as small holes or positioning of baffles, or sizes or shapes of inlets, you have completely changed the thermodynamic cooling process of the engine, and you can make zero comparisons between the two...mount even identical engines (these are not, despite what you may think) on two different airplanes, swinging different propellers, at different speeds under different conditions in different cowlings with different baffles with different inlets, different inductions, different cowl openings...you have different engines and most certainly you do have apples to oranges comparisons.
Same spark plugs and timing? Same cooling inlet area, outlet area, and shape? Same baffling, same fuel flow, same airflow? No.
Moreover, operating at 30" isn't much of a boosted pressure...certainly not enough to cause excess wear and damage. Think about it...the airplane at sea level when normally aspirated runs at that value, paricularly with ram rise in flight. That's not highly turbocharged, that's turbonormalized...and yes, there is a difference. You're boosting to sea level pressure only...no different than what the normaly aspirated airpalne is capable of seeing. Blowby isn't increased, nor is it really an issue. I believe you mentioned darkening of the oil before, which is a ridiculous measure by which to assess wear in an engine...color is irrelevant and meaningless. You appear to believe this is a result of blowby and evidence that one engine is experiencing more wear, which puts your observations squarely in the realm of those of a housewife understanding her car. You can do better than that.
During a standard compression check I flow 80 psi or greater to the cylinder, and some of it may or may not leak past the valves or the piston. An engine close to TBO may have nearly perfect compression, or it may not. TBO is a reference number, and other than some legal implications, it's largely imaginary. Further, an overhaul may be nothing more than verifying that parts are within tolerance and putting them back...laying some lack of creditiblity to the idea that engines wear out at TBO...TBO doesn't mean much, and overhaul means even less.
W(h)eather you believe it or not, you have two different engines there, in two different aircraft, under two different circumstances and two different operating parameters. Apples to oranges. Examine two identical 402's, operating one at the lower RPM and manifold pressuree setting, and the other at the higher power setting, and if operated properly, you won't see much difference, if any. Especially at those minimal power settings.
Of course, when you're running 30 inches, you're running the same induction pressure as you get with the normally aspirated engine at sea level, when the normally aspirated engine is SHUT OFF...that's barometric pressure, and that's what your manifold pressure gauge will read when the airplane isn't even running...think about it. What you have are thermal differences which are not a consequence of the manifold pressure, but the combustion process and your mixture and power settings, being operated by different pilots at different times.
I ran a fleet of nearly 30 airplanes that all had the 0-520's, some turbocharged, some not. Most everything made it through TBO without worries, and most could have gone far beyond, very few problems, because we looked after them. They were regularly used, regularly inspected, some coming in for 100 hours two times a month. When I flew the boosted airplanes, I seldom used much boost because I didn't need it, but operationally, we had better value with the normally aspirated because they weighed less and were a little less complex and did the same job.
When you shut down your turbocharged models, are you running them for five minutes to cool the turbo and help eliminate coking in the turbo bearings? your black oil is the result of residual oil in the case following a change, and thermal differrences. Blowby does contribute to darkening of oil, but may be considered inconsequential, becuase to some degree you're always getting it, and if it's enought to be causing breakdown of the oil, you're already low enough on your compressions (and cylinder pressure isn't the cause) that you need to be doing something about it. Regular oil changes are the order of the day. If you're not operating the engine properly, you're going to see more wear. Adequate warm up and cooling periods, as well as preoiling, will make a lot of those problems and the wear you're seeing go away.
As far as running at 30" being the cause of excessive wear...it's good for a laugh, but not very realistic.
How do you suppose we could run 45" or more inches of manifold pressure and still have engines left? How do you suppose the normally aspirated engines run all day long at the same 30" hg. of turbonormalized induction pressure as your 402, without a hiccup? Truth is that you're not providing anything to that engine that it doesn't see sitting on the ramp cold and quiet...other than heat and pilot abuse.
Again, nice try.
Look I know I could go on an on and you would always have some sort of counter because you know everything. But comparing there 2 are not apples and oranges. Are these two exactly identical circumstances, no, but relevant to this conversation since no one else has given any other comparisons, including you, it's the best that we've got. Comparing these to are like comparing green apples to red apples. Also the fact that you say the 402 is turbo normalized leads me to believe you don't know a dang thing about the 402. They are not turbo normalized, 30 inches is just the cruise setting that we use, you can use 32inches and 2300rpm and they go up to 34.5 inches and 2700rpm for max power in the B models and 39.5/ 2700 in the C, BUT the C DOES have a different engine, still a 520 but a different model, where as the B's use the same model 520. The inlets are the same, the baffling is different and the outflow are different to allow MORE cooling on the 402, which should make the engine last longer. Also they are swinging the same propeller and both A/C go the same speed. So again for the purposes of this discussion this is as close as it gets, since no one has come up with a better example.
Also I never said it causes excessive wear, it increases wear. Blowby IS increased, anytime you put more pressure into a cylinder you will inevitably get more gases that pass by the cylinder rings (more blowby), they teach you that in basic auto shop! Also color of oil is not irrelevant, if your oil is dark you have more particulates in it, which will break the oil down chemically or cause it to form sludge blocking oil passages, again basic auto shop here, nothing earth shattering. If blowby and oil color was meaningless and irrelevant then we wouldn't have systems to remove blowby or change our oil. Why do you think you can drive 100,000 miles on your transmission fluid (which is just oil) but only 3,000 on your engine oil? It's because blowby breaks the oil down, since there's no blowby gases in the transmission the oil doesn't break down.
You also keep referring to the fact that when you cruise in the 402 at 30 inches it's the same as a N/A engine at sea level. This is true, but a N/A engine is only going to be at that pressure for a few seconds because even at full throttle the instant you break ground the pressure will drop. No N/A engines cruise anywhere near 30inches and in most cases you don't even get 30inces on takeoff since the air is restricted slightly through the induction system and filter. Also I still don't understand your rationalization that an engine not running on the ramp showing 30in is the same as a running engine at any MP, that just doesn't make any sense.
We run or engines far past TBO through approval from the FAA, the 402 goes from 1400hrs to 1800hrs and the 310 goes from 1600hrs to 2200hrs. The 402 still gets a lower TBO because of the simple fact that they do wear out faster. Why because we're running higher pressure through them, which produces more power, which produces more heat, more blowby and just generally causes things to wear out alittle faster over the long term. Is it excessive wear no, but it is increased wear.
And yes, we use adequate warm up, cool down and cool the turbo's before shut down.
The end.:)
Apparently they didn't teach you that in A&P school...not a mechanic are you? (I am). Why, because it's not true. Nice try though. You're operating your aircraft in a turbonormalized condition, operating them only to sea level pressure...you're not inceasing wear in anything. Not even remotely close.
You're operating it in a turbonormalized state, not exceeding sea level pressures; anything more that is within limits of the engine is irrelevant, because you're not opertating it under those conditions. THINK!
As youstated, diffrent engine models, and therefore your comparison is no good. Different baffles, different inductions, different aircraft...you simply can't turn an apple into an orange. Nice try, though.
That's a very simplistic, but uneducated and wrong way to look at it, but once more, nice try. Too much cooling is just as bad as too little, but both issues are irrelevant. How the engine is cooled, where, and when is much more important, just as is peak oil temperatures...your oil breaks down thermally long before it's affected by contaminants...which accounts partially for the color, along with contaminants picked up and in suspension. Simply because one has more cooling available doesn't mean it lasts longer or is in a better state. You need to do a little study before you pursue that one.
In any case, that doesn't address the operating parameters, nor the warm-up, cool down, or other facets of operation that most operators neglect. You are giving the turbo a five minute cool down after landing, right?
Aaah, again, wrong. You really should study a little on this, before you pursue it. Next you'll be telling us you can tell the condition of the oil by it's color, or that the color has any meaning at all (it does not). Not such a nice try. READ!
Again, very wrong...more than apples to oranges there...no comparison between circulating an operating fluid through a non-combustion transmission, an entirely different chemical formulation from engine oil, and engine oil in an internal combustion engine. Why not compare toe nail polish to beer? To what systems are you referring to remove "blow by?" Are you talking about crank case breathers? You understand that there's a lot more going on in that crank than merely venting for "blow by," and that the breather is necessary even if there isn't any "blow by?" You do get that, right? You're aware that some companies had systems for many years which pumped raw fuel into the oil after shutdown and before start as part of the oil dilution system...intentionally putting combustion products into the fuel, right?
Actually no. A properly designed induction in a normally aspirated engine will experience a ram air recovery and even ram air rise with the ram effect of the propeller and forward airspeed...getting thirty inches or more is not uncommon in normally aspirated airplanes close to sea level.
One surely can get full barometric pressure in a normally aspirated engine...especially at sea level. As for the explaination about an engine at rest at sea level...you assert that pressure damages engines, and the terrible, awe inspiring tubonormalized setting of 30 inches of manifold pressure is causing excess wear in your engine...no it's not, and that's no greater value than you'll see on the gauge when the airplane sits for extended periods doing absolutely nothing. The manifold pressure you're seeing on the gauge is irrelevant. You get that part, right?
If the oil is changed regularly, then the issue of blow by is irrelevant. Again, irrelevant. Once more, sing it together, irrelevant. If you are seeing blow by to the degree that it's causing engine damage or wear, then you have some serious mainainenance faults and need to look at doing better inspections. Even if that's happening, it's not going to cause the engine to wear out faster. Not happening.
If the engine is operated within temperature limits, you're not wearing anything out any faster.
Your comments do indicate why the FAA mechanic certificate takes lot more doing, and is a lot more complicated and involved than any pilot certificate...and why you need one before you put your fingers in something you don't understand. Do a little research on your claims here, then get back to us with your new found knowledge. I'm sure it will be enlightening for us all.
How many 310s cruise at sea level?
I spent a lot of time cruising at SL, most of the time with an engine shutdown.
AvBug participates in class, BUT does not pay ATTENTION!:smash:
Here's alittle article about Turbo-Normalization. http://www.nar-associates.com/technical-flying/turbo/turbo.pdf
Not a mechanic, but I have a pretty good understanding of mechanics since I have some engineering background. I am not operating in a turbo-normalized condition. Running 30 inches MP in cruise would be equivalent to running 100% power in cruise, which is not the case I'm running at 65% power. No piston A/C that I've seen yet has cruise settings listed in the POH for 100% cruise power. Also as stated before I do exceed sea level pressure in a 402 every time I take off and climb since I DO take off at full power, which is 34.5 inches MP and 2700 rpm in the B model, and climb at 33in MP and 2500rpm. I also can run if I choose at 32in MP and 2300rpm for cruise.
From the article listed above.
"First, what is turbo-normalization? Simply put, turbo-normalization uses an exhaust gas turbine to drive a compressor which increases the engine intake manifold pressure. A turbo-normalization system automatically limits manifold pressure to that at sea level at all altitudes up to the system critical altitude."​
Ok so we've established a 402 is NOT turbo-normalized, and the A/C IS operated out side of sea level pressures.
"BUT the C DOES have a different engine, still a 520 but a different model, where as the B's use the same model 520."
Again not paying attention. I said the C model uses a different model, I'm comparing the B which DOES have the same model IO-520-M series.
From the article above.
" you can consider an internal combustion engine as an `air burner'. If you increase the amount of air in the cylinders, then an increased amount of fuel can be burned. Because fuel burned is power available, the horsepower is increased. The price you pay is increased engine wear because of the higher operating pressures and increased heat output."
I studied and I'm right.
As stated before yes we allow for proper warm up and cool down, no we don't cool the turbo for 5 minutes, we cool it for 4 minutes at 1000rpm as per the POH.
http://www.nordicgroup.us/oil.htm#The Dark Oil Myth
"Dark oil does not indicate the need for an oil change. The way modern detergent motor oil works is that minute particles of soot are suspended in the oil. These minute particles pose no danger to your engine, but they cause the oil to darken. A non-detergent oil would stay clearer than a detergent oil because all the soot would be left on the internal engine parts and would create sludge. If you never changed your oil, eventually the oil would no longer be able to suspend any more particles in the oil and sludge would form. Fortunately, by following the manufacturer's recommended oil change interval, you are changing your oil long before the oil has become saturated. Remember, a good oil should get dirty as it does it's work cleaning out the engine. The dispersant should stop all the gunk from depositing in the oil pan."
I'll give you that one, but I still stand by that because the oil turns dark faster that there are more contaminates in it from blowby.
Yes I understand that you need a crank case breather for more than just blowby gases. But their main purpose is to provide pressure equalization of the crankcase and remove blowby gases. Also you can not honestly tell me that if you increase the pressure in the cylinder that you won't increase the blow by gases. Piston rings are not a prefect seal, this is why we get oil consumption and blowby gases. So since it's an imperfect seal any increase or decrease in force exerted on it will increase ore decrease the amount of gases that pass by it. Also yes, transmission oil does have a slightly different formula, very slightly. But you even stated in your response why it last longer as I did originally, because it's not in a combustion engine. Why does that have anything to do with it? BLOWBY GASSES! An internal engine has it a transmission doesn't. PAY ATTENTION!
http://www.autoshop101.com/forms/h63.pdf
http://www.bobistheoilguy.com/blowby.html
"Blow-by occurs when the explosion that occurs in your engine's combustion chamber causes fuel, air and moisture to be forced past the rings into the crankcase."
[SIZE=-1]"Blow-by inhibits performance because it results in a loss of compression. When the expanding gases slip past the rings they cannot as effectively push the piston down and make the vehicle go. As a result the car will have less horsepower. This also results in a loss of fuel economy. [/SIZE]​
[SIZE=-1]When the fuel, air and moisture slip into the crankcase they contaminate and dilute the oil in the crankcase. [/SIZE][SIZE=-1]Among the many gasses in your compression chamber are unburned fuel, moisture, sulfur dioxide and soot. Once these gasses slip into your crankcase they can dilute into your engine causing great damage. "[/SIZE]​
One surely can get full barometric pressure in a normally aspirated engine...especially at sea level. As for the explanation about an engine at rest at sea level...you assert that pressure damages engines, and the terrible, awe inspiring tubonormalized setting of 30 inches of manifold pressure is causing excess wear in your engine...no it's not, and that's no greater value than you'll see on the gauge when the airplane sits for extended periods doing absolutely nothing. The manifold pressure you're seeing on the gauge is irrelevant. You get that part, right?
Yes 30 inches are uncommon even at sea level in a N/A engine. Ram Rise is insignificant in a piston engine A/C. The MP indications are not insignificant since they indicate directly what the pressure is in the intake manifold, thus the power that will be produced. Sitting on the ramp is irrelevant since the engine isn't running it's not producing power or heat thus not incurring wear! A/C do not operate at sea level for more than a few seconds since the second you leave the ground your going above sea level and pressure drops. Also again no piston A/C has cruise setting for 100% power, most cruise between 75% and 55% power.
Last I NEVER said excess wear, I said INCREASED wear, which with the articles I've listed prove my point. By increasing your manifold pressure your increasing your power out put, increasing your heat output, increasing your wear, and decreasing engine life.
So before you go spouting off about how great you are and why pilots shouldn't doddle in mechanical affairs, take alook at your flawed idea's.
Now I've shown you proof and wasted far too much time on this thread, I'm done.
There are numerous factors that contribute to engine life. Cylinder pressures are one reason, the higher the pressure the hotter the cylinder walls get. If the cylinder walls get hot, valves cannot cool properly, since they distribute heat through the cylinder head. If you want to increase engine life (no matter what engine MP/RPM combo you use), you must lean properly. If you are above 85% on any piston engine, you must run a full rich mixture, period. Above 9000 in a normally aspirated engine, no matter where you lean it, you cannot hurt the engine because the engine isn't putting out enough power. In a turbo charged engine (or a normally aspirated one at high power settings), that would be 70-85% power, you must stay away from leaning for best power (40-100 degrees rich of peak). When you lean to these settings, you increase horsepower, but you also are in peak pressure range and your CHT's are the hottest. Exhaust valve temperatures are the hottest at 25 degrees rich of peak. So, opeating at high power settings requires leaning to 70-100 degrees lean of peak. Cessna teaches new owners to run their engines 50 degrees rich of peak. Look in aero trader or something like that and see how many T182's and T206's that have already had a jug or top end done before reaching 1000 hours. Look at a Columbia or a Cirrus, these guys preach lean of peak and they aren't having problems with this. A common LOP power setting on a TSIO550 is 31.5" and 2450 RPM with 17.5 GPH fuel flow. This settings is way over square, but you have cool CHT's (usually between 330 and 360), low cylinder pressures, and still have a pretty decent true airspeed. Running lean of peak with an engine like a TSIO550 multiply 13.7 times the fuel flow and that will give you the horsepower output at that setting (only works LOP). So, I kind of got off subject with this, to make a long story short, run lean of peak, and get a good engine monitor.
