Yes, avbug, us ignorant, neophyte instructors have been using that "simplistic" description since...oh, the beginning of "modern aviation"...or, the introduction of nosewheels on training airplanes.
Don't get upset merely because your daddy never removed the training wheels. When I was a "neophyte" instructor, I had long since been flying without the training wheel, and I never taught the antiquated and false concept that two molecules beginning at the leading edge of a wing have some innate need to spend time together at the trailing edge. I taught correct aerodynamics, and never had a student fail to grasp these basic concepts. Merely because you never understood or taught correctly, don't get upset. That's your fault.
First of all, that's the way it is taught in FAA publications, secondly, it is a simple,easy-to-understand description of bournelli's theory. Sometimes, it's better to over-simplify to get the concept, then go back and clean-up any important details that were not exactly accurate.
Because something is written somewhere, you should teach it. I get it. The FAA publications also cited ground effect for years as a "cushion of air" beneath a wing. Doubtless you taught that little nugget of misinformation, too...completely oblivious to the fact that it has nothing to do with ground effect. You probably never taught that ground effect is diminished upwash, and therefore a reduction in induced drag, due to the inability of the airflow in front of the wing to produce a local increase in angle of attack...which of course comes from reduced pressure above the wing owing to...you got it! Bernoulli's principle. More to the point, owing to downwash; air moves down in back of the wing, it moves up in front of the wing, local angle of attack is greater than the angle between the aerodynamic chord line of the wing and the free airstream. Reduce this local angle of attack, reduce induced drag, and wallah, ground effect.
But that wasn't in the FAA publication...which was wrong...and you taught it wrong, doubtless. And justify it on those grounds. Therein lies the difference between an instructor, who administers a syllabus, and a teacher, who teaches a student. You are clearly an instructor.
You truly believe it's right to teach incorrect information, then go back and correct the lies and mistruths you've told? What an increadbily innovative, though seriously misguided concept!
Your description has not taught me anything. You say "it is this venturi effect which causes an increase in velocity..." You are making a statement of fact, not an explanation in terms that the student understands.
I wasn't aware that this was teach nosehair day. How obtuse of me. But then, you're the instructor, albeit the "neophyte" instructor? I suspect from your rant that nobody teaches you anything, do they? After all, you're the instructor, you're in charge, and you have FAA publications to parrot.
You have to explain "the venturi effect". Isn't that like all the molecules of air (or water) have to speed up to get through the restricted space?..and don't they all end up more or less together at the other end of the venturi?
No, they don't. Nor should they...where molecules end up isn't important to the discussion of why the pressure drops, and that's the point. A venturi is something a student understands; every student has placed his or her finger over a garden hose, seen the effect in the velocity of the water coming out the end, understands that as a relatively incompressible fluid is pushed through a restriction, it goes faster. Every student has seen a football player run and tackle a dummy, or another player. Every student understands that a charging linebacker has a lot more energy in front of the player, than to the side. Every student may be shown this by having the student push hard against a wall, and then be toppled by finger tip pressure from the side.
Every student can then easily see that a velocity increase moving through the "venturi" above the wing, the restriction that is similiar to a finger over a garden hose, is "increased" in one direction...toward the trailing edge, but decreased in every other direction. The student can be shown that a certain amount of energy is available; as it's value increases in one direction...it's pressure value drops. The student can see this in a balloon that deflates and flies across the room, as it's drawn on a chalk board, with little explaination. I've never seen a student that couldn't grasp these things, though apparently you feel it's beyond the capabilities of the student. Perhaps you just instruct really stupid students? I find that hard to believe.
So, there's a lot more to this story than we get into with a beginning student, usually. And that is usually enough. If you know the aerodynamics in the PHAK, that is enough for pilot certification. Even though it may not be precisely accurate.
I find it hard to believe you just said that. Apparently you're one of those who feels that minimum standards are the rule...meet the minimum and we're all golden. I have never taught by the practical test standards because I consider them minimum standards. I teach to proficiency, which is not found in the practical test standards. A proficient student will far exceed any toleances found in the PTS.
Likewise, who would be foolish enough to suggest that "it's enough?" What a mediocre, lazy attitude.
Even tough it may not be accurate? Wow. If that statement doesn't define mediocracy, then what does? You teach just enough, even though it may not be accurate. Heaven forbid anyone I know falls into your clutches. A craftsman strives for something higher. Even a "neophyte."
It is also healthy for flight instructors to discuss, among themselves and interested students, the finer points of the lift theory, but healthy discussions don't "put down" persons who either don't know, or choose to simplify.
Put down? I stipulated that a particular theory often espoused is done so by the ignorant...and it is. Either you wilfully teach incorrect information, or you do so ignorantly. There is no inbetween, no middle ground. Either one is lying, or simply spreading misinformation in ignorance. So which is it? Your call.
Remember: K.I.S.S = Keep It Simple Stupid
Perhaps you ought to make that KISSAI for keep it simple stupid and inaccurate. You really feel your students are stupid? I'm betting you are or were one of those "neophyte" instructors who feels that instructing is "time building," and "paying one's dues." That students are a means to and end, and that there are few punishments greater than being forced to ride around with those simple students while they pay you to put your certificate on the line for their simple, stupid, butts? Close? No cigar?
That's sad.
