  • Logbook Pro for Apple iOS version 8.1 is now available on the App Store. Major update including signature endorsements and dark/light theme support. Click here to install now.
Oil Stain Removal From Pilot Shirts
JetProp
Total Time
10000+
I've ruined many a fine aviator shirt from oil drips during preflight. Any ideas on stain removal of Exxon 2380 turbo oil or its equivilant? Or should I just buy a new shirt? Thanks!
ksu_aviator
GO CATS
Total Time
4100
I have used Ivory bar soap in the past and it works reasonably well. In fact, I carry it in my overnight bag just in case I need it.
Its the same Ivory soap you would use for washing your hands or in the shower. Just rub the soap against the spot with some hot water (in a sink) then use your fingernail to work out the stain. It works for me.
alimaui
Total Time
150+
Go to the store and buy MURPHY'S OIL SOAP. It is sold in a spray bottle and a bottle of non diluted with a regular twist off cap. You want the non diluted. It is wood cleaner, but it works wonders on clothes, for just about any type of stain. Scrub the drips with an old toothbrush generously covered in the oil soap. (If necessary soak the spot in a little murphys) Then stick it in the wash machine with the rest of your clothes on regular cycle.
Disclaimer... This works, but use care on colored (especially dark) shirts. I would not recommend the soaking of colored shirts, for fear that they might not be colored any more if soaked for too long. With white shirts be generous. And as always, as long as you have not dried your shirt in the clothes dryer (or over heat) you can still wash it again to get your stain out even if it does not come out the first time.
Ali
abexpilot
Active member
Total Time
4000+
Try GoJo, that stuff in an orange can that doesn't need water. Smear it on the stain and then wash it. It also works pretty well for ring around the collar.
avbug
Total Time
n/a
Gojo works. THe white stuff is better than the orange, and not as likely to stain. Don't let it sit too long.
Stain stick.
Coca cola, believe it or not. Test it on something that's similiar with respect to fabric, but that doesn't cost a lot, or test it on a hidden part of the shirt. Let it sit for a while, but don't let it dry. Sometimes it's useful to soak the item first, wring it out, and then pour coke on it. You'd be surprised what coke will take out. (works well on blood, too).
If you're removing oil, be sure you're happy with the shirt before you dry it, because once it's been dried, it's set for life. I have lots of clothing stained with H-5606 and 120 weight oil as a testiment to a grungy life around airplanes, and mistakes made laundering clothes. (In fact, with the exception of my "office" clothes and the sunday monkey suit, everything I own bears distinct evidence of airplane contamination).
Personally, I believe white shirts around airplanes are a MISTAKE.
A Squared
Total Time
11000
Being that I fly round engine airplanes, I'm probably more familiar with oil stains than most (Avbug can relate) I've found two products which work well:
Simple Green, and Jobmaster cleaner/degreaser (get it at Costco or Janitorial supply places) I usually take my oily clothes, spray the stains with a spray bottle, scrub the stains with a scrub brush, then let them soak overnight in a bucket filled with water and the degreaser or simple green. After soaking, I may scrub the stains some more with a brush, then I wash them normally. This will take some of the color out of the fabric, and I don't know how it works on white, as I don't wear white around our airplanes. I think that one of the keys to getting the stain out is vigorous scrubbing. For hotel room stain removal, pack an old toothbrush, the stiffer the bristles, the better.
Clean shirts to ya
Birddog
On a mission...
Total Time
8k
I have found that Fels-Naptha soap works great on the various types of grease you encounter under the Be1900. It comes in orange bars and I usually rub some on the spot, work it in with a soft scrub brush, and rinse under the tap. It has saved my shirts several times. It also works on pens that exploded at altitude.
FearlessFreep
Total Time
What works removing oil & grease? The same thing that works taking it off your pots & pans!
I use dishwashing fluid and powdered laundry detergent with a tooth brush and rubbing the fabric against itself. Works great on collar stains as well. I find I have to prewash all my pilot shirts paying attention to the collar, pen pocket, shoulder area, and the button holes. This usually will keep the shirt looking pretty good.
I have found this mixture to be somewhat effective on the other big stain... ink as long as it is not too big.
Another ink stain removal tool I have used is Denatured Alcohol. It is best to use a small container and soak the stain, then use fresh alcohol to rinse the remainder off. This can become a bigger mess if you do not accomplish the procedure correctly. It could save you the cost of a new shirt but use with caution!
Well enough of my domestic diatribe, we'll leave the rest to Martha "It's A Good Thing" Stewart!
Have Fun!
Smoking Man
High Speed Aluminum
Total Time
7701
WD-40
I know that it sounds strange but Oil based stains are best removed with oil based solvents or products. "Talking dirty with the Queen of Clean" this book off of Oprah is my information.
I know but my Wife had the remote.
Smoking Man
Squanto
Total Time
5850
Try Lava Soap
Lava soap will take the hair off of a bear or a full grown mountain gorilla (don't ask me how I know) and it works pretty good on oil stains. Just make sure there no one you care about wearing the shirt when you do it. It burns man. Good luck.
sydeseet
Huge Member
Total Time
5001
A very domesticated fellow pilot I work with swears by brake cleaner. Buy an aerosol can of it at a parts store, turn the shirt inside-out, spray it on the stain area and rub it together, and then throw it in warm water and wash it. He's been using it for years and tells everyone about it. It will damage sensitive fabrics (silk, wool, etc..... but we all know that pilot shirts could survive a nuclear war - as long as they don't catch on fire) Good luck.
Simon Says
New Airbus Regional Jet
Total Time
11000
Have the FO do the dirty work.
troy
Total Time
~500
I'll second "Simple Green", as a mechanic. We used it in the Navy as flight deck cleaner in the scrubber and I currently use it around the shop and at home by the washer/drier.
flyhi
Total Time
1650
If you are in a bind (oil on shirt..pax show up) then throw some club soda on it until you can get to your room or airport bathroom to do the soap thing. club soda will keep the stain from drying out and it will take out most food stains and light oil and grime. it's also safe to use on darker and delicate clothing.
skychaser
Member
Total Time
growin
A 3rd vote for dish soap
works every time! i use whichever brand is available and it works every time!
stingray
Senior Member
Total Time
some
During my Cape Air days(C-402s), we said if you don't have oil or grease stains on your shirts you didn't do a proper pre-flight.
Ok SHOUT it out with some scrubbing it comes out. I've had shirts that where stained that I wasn't using anymore. It got some week old stains out of these shirts and made them usefull again.
Timebuilder
Entrepreneur
Total Time
1634
It's true. CRC Brakleen will take off just about anything. I haven't tried it on a white shirt, but if I get an oil stain, I'll bet it will work.
Chunk
SkyFuzz
Total Time
This stuff will clean ANYTHING!
Trichloroethane. You can get it from..well, I'm not sure. My dad always had it around the house, but he worked for an oil company. I think electronic repair guys might be able to get it.
Chunk
