desert pilot
- May 29, 2002
VFR on Top said:Continental O-470 -- min: 9, max: 13, fill to 12 for extended flight.
Lycoming O-540 -- min: 5, max: 9, fill to 8 for extended flight.
icefr8dawg said:If the 540 in a 182RG holds less than 12 qts it's an anomoly for that AC because every 540 I've dealt with has held 12.
desert pilot said:I cannot remember the markings on the dipstick-would it be with -minimum or a number for the min.?
Remember that the paralell valve O-540 in the 182 is a completely different engine that the angle valve IO-540 TIO-540 engines like those found in the Navajo. That being said, the TCDS for the O-540 engines lists a maximum Oil sump capacity for all variants of 12 qt, inclyuding the specific dash models installed in the 182. However that is just an indicatin of how much oil it can hold, the airframe manufacturer may reccomend a different amount as long as it complies with the minimum quantity. The *minimum* Oil quantity for those engines is 2-3/4 quartsicefr8dawg said:If the 540 in a 182RG holds less than 12 qts it's an anomoly for that AC because every 540 I've dealt with has held 12.
I suspect not. The TCDS for the O-540 lists oil sump capacity as 12 qt for all of that series engine, specifically including the J3C5D and L3C5D. I would expect that if Lycoming built an engine with a different oil pan specifically for the 182, it would have a seperate designation.JCJ said:It wouldn't surprise me if the R182 O-540's had a lower oil capacity than other O-540's. In the R182, the engine was derated to 235 HP, and the oil sump pan had to be small enough to accommodate the retractible nose gear.
Like I said previously, the information I gave is straight out of the FAA TYPE CERTIFICATE DATA SHEETS which you, yourself have proposed as the definitive source for "official FAA approved data," That *IS* the answer I have given. The TCDSs I quoted are for O-540 and the O-470, specifically, the 12 quart figure for the J3C5D and L3C5D is in TCDS E-295, page 3.JCJ said:I must beg to respectfully disagree:
Here is the link to the 3A13 TCDS from faa.gov
http://www.airweb.faa.gov/Regulatory...MU61Z/3a13.pdf
This is the relevant TCDS for the Cessna 182 series, including the R182 and TR182.
The max oil capacity for these aircraft (R182 and TR182) is clearly listed on page 16 of this document and is nine quarts.
Oil capacity and other data for other 182 series aircraft are listed elsewhere throughout the document.
I also owned a R182 for a while, and I regularly fly a 182T (with the Lyc IO-540), but my answer isn't based on that, it is based on FAA approved data.
I realize there are many more important things in the world, but the question was asked and since there is an answer based on official FAA approved data, I think that's the answer that should be given.
If you have FAA data that says the max oil capacity of these engines is indeed 12 quarts, would you please post it?
A Squared said:Like I said previously, the information I gave is straight out of the FAA TYPE CERTIFICATE DATA SHEETS which you, yourself have proposed as the definitive source for "official FAA approved data," That *IS* the answer I have given. The TCDSs I quoted are for O-540 and the O-470, specifically, the 12 quart figure for the J3C5D and L3C5D is in TCDS E-295, page 3.
Like I said previously (I really hate repeating myself for the benefit of people who can't or won't read) the 12 quarts is a *MAXIMUM* possible capacity, not a *recommended* service quantity, the *recomended* service quantity would come from the airframe manufacturer.
Now, If you believe that the the airframe manufacturer's reccomemdations invalidate the engine manufacturer's data, I respectfully suggest you address your concerns to Textron Lycoming and the FAA.
