Odd Technique on B-350 King Air
satpak77
Marriott Platinum Member
Met a guy the other day who flies a B-350 King Air - claims he goes into reverse "every time, absolutely every time" after landing (runway is 6000 feet) and also immediately puts flaps up upon touchdown to "help with braking"
WTF
comments? I have never heard this, in over 10 years of FSI recurrent and meeting other operators
you never heard it for a reason, because it is foolish. Wait until he grabs the gear handle.
Nothing more than ground fine is necessary for most normal landings in the B350 (and all the KA's I've flown)....I suppose flaps up landings or operations into extremely short runways would be a couple of exceptions. It just makes a lot of noise and kicks up dirt/fod....there just isn't much benefit to using reverse at the normal touchdown speeds of the airplane.
Raising the flaps on the landing roll is goofy.
Bet he has never been to Flight Safety. I did fly with one bonehead in a 350 many years ago that wanted to pull up the flaps right away on the runway. He did it once and that was that. He was an old guy used to flying single pilot. We had bought this King Air and hired a few contractors to fly it. Initially, none of us wanted anything to do with it. Turns out, it was a lot of fun and a nice break from flying a G4. Enjoyed it a lot. Especially, the VFR up and down the NE corridor.
the guy is not wise. we'll read about him soon enough. The flap retraction wont help with a plane of that weight. Ground idle provides plenty of aerodynamic braking.
Ive landed a 350 on 3500' runway plenty and never had to stomp on anything.
Wasn't there an internet post a few years back about a guy gearing up a King Air doing something similar?
Where the F do people get these "techniques?"
:erm:
I cant think of many jets that need much extra braking on 6000+ft, nevermind a King Air.
:erm:
I hear you my brother....
Cadors Number: 2009C3607
Occurrence Date: 2009-12-23 Occurrence Time: 0233 Z
Occurrence Location: Winnipeg Intl (CYWG)
Make: BEECH Model: E90 Year Built: 1976
Detail Information
Date: 2009-12-23
Narrative: SN 696M, a Beech E90 medevac flight operated by Skynorth Air, landed on Runway 18 at Winnipeg and during the roll out, the landing gear collapsed. The aircraft came to stop on Runway 18 north of Runway 13/31. PAG 504, a Perimeter Metro, was on final for Runway 13 at the time was pulled up by tower and diverted to Runway 31 for landing. Runway 18 was NOTAM'd closed until 0600z. There was substantial damage to the aircraft but no injuries to the 3 crew and patient. TSB report to follow.
Date: 2009-12-24
Narrative: UPDATE TSB reported that the Skynorth Beech E90, registration C-GSNM, had touched down on Runway 18 at Winnipeg, MB on a medevac flight from St. Theresa Point. The landing gear selector was inadvertently selected up when an attempt was made to raise the flaps immediately after touchdown. The ground/air safety switch was not yet in ground and all three gear cycled up. The aircraft settled onto the runway and was substantially damaged. There were no injuries.
Obviously not necessary, but not the end of the world. With the King Air propeller system there are about nine ways to skin the cat, it's part of the fun. e.g, after touchdown dumping the props into reverse, then immediately back to ground fine before the engine spools...kills the prop RPM, kills the noise, and delivers a measured amount of gentle decelleration if that's what you desired, and no additional engine wear. There are a million ways to make your turnoff gracefully, its part of the art form. I miss the Beech already after a whole 2 weeks.
Probably a procedure used from an older airframe....retracting the flaps after touchdown was SOP on the DC3...like I said older airframe.
I flew a late model though.......1942!
I always put the flaps up as soon as I turn off the runway. I fly single pilot. Maybe this is a bad habit, but I have never thought of it that way. The flap selector and gear handle are in completely different locations and take a different technique (the gear handle requires you to grab it, pull it out and then lift up, as the flap simply requires a finger or two to flip it up). Open to critique.
I know a guy like this but he flew a 200. IT DROVE ME INSANE. Mostly just the reverse part...out of the corner of my eye I would watch the passengers lurch forward and back. It was embarrassing. I took great pride in NOT doing it when I flew.
standard procedure
http://www.youtube.com/watch?v=1fy6oTUC49A
Piedmont DC-3 landing on grass strip...flaps retract on landing roll out. Neat video.
Pulling the flaps up on touchdown in a DC-3 is pretty much standard practice. Overwise with a slight increase in AOA it will start flying again. With flaps down the C-47 will come off the ground at around 50 Kts with the tail down, Vmca is 76 Kts. BTW Maybe this guy started flying 3's?
former airline guy. 727, 757 guy, laid off
unless
you shouldnt touch anything until clear of the runway.
unless it is a recommended and trained procedure, that does not involve a configuration changer.
Yep - makes sense.
While I disagree with the practice... there are some operators that believe every landing should be 'Maximum Braking/Shortest Landing & Stoping Distance' .... I have heard there are some airline operators that disiplne pilots who do not make certain turn-offs at certain airports... Could have been some drunk airline guy making stuff up at the Embassy Happy Hour but its what he said.
I prefer not to wear planes out and not to scare my pax ;)
I agree. I have lots of single pilot time in a 350 and ground fine works great for most landings.
I contract in all manner of King Airs and have run into the flaps up upon touchdown quite a bit. I comment that it's not the best practice due to distraction, asym flap retract, and not needed but to no avail. People do what they want regardless of the facts. Same folks are probably still putting butter on burns and peeing on poison ivy.
Side note, I flew with a guy in a Caravan who approached at flaps 20 then at about 10 agl would pull flaps to 10; not smart but he claimed it made smoother landings. Some folks are weird.
