From what we are unofficially hearing the F/O noticed that the reversers weren't deployed when the Capt said that he couldn't get the reversers deployed. To know for sure we will have to wait for the investigation to be completed. The CVR will show the investigators exactly what the Capt said, or didn't say.FR8mastr said:What do you make of the FO's statement in the above article? I am not being smart, I dont know the reverser system in the 73
b82rez said:Once the autospoilers extend, a go-around usually isn't the best idea
Donsa320 said:That, Gentlemen and Ladies, is why we have not been using any credit for reverse in computing landing distance since I've been flying reversible airplanes. That being since 1953.
I have no sympathy for Boeing, SWA or the FAA in deciding otherwise in the later 737's. It was bound to happen. I'd guess they will now pay.
DC
[email protected] said:I don't fly 737s, but it is my understanding that for the thrust reversers to deploy on that aircraft two conditions must be met to prevent inflight deployment:
-You must have Weight On Wheels &
-The wheel speed must be atleast 60kts
When the aircraft landed, the tires may not have spun up to 60kts because of the icy runway conditions. If that was the case, then they wouldn't have been able to deploy the TRs. Maybe that's what happened???
C40_Pilot said:Wow, for a board of professionals, some of the comments have not been.
kevdog said:Sounds a little bit like the Captain could have forgotten the reversers, and the FO caught the error a little too late. At least after reading this NTSB report.
Alin10123 said:Couldn't they have put the spoilers down? Or would that have slowed them down enough to cut it close getting back up off the ground?
That is something with Boeing products that I never understood. If the spoilers are out, and power is added while not in reverse, then they should retract (slam down) without user input IF they were deployed from an "armed" status, not manually deployed. If they WERE manually deployed, a certain N1/EPR or throttle position should stow them automatically. Cali, Columbia in an AA757 should have taught them that. Except in Reverse and icing, and I'd like to think idle power in any Boeing would be enough to keep the wings clean, there is not a condition that calls for power to be added or maintained with spoilers extended. Even Challengers and Lears (older ones at that) auto-stow the spoilers when power not at idle if they are armed (deployed automatically). I'm sure there are other A/C types that do that as well.ultrarunner said:Nope, they'd have had an even worse crash. Think about it. Touchdown at 140 kts or so, spoilers fire, engines at idle.
If you immediately initiate a bolter, by the time you stowed the spoilers and the engines came up to toga, the'd have prly been through the fence, and at a faster speed.
Better to have a car crash than a plane crash...
