mcjohn
- Jan 23, 2005
I was just down at KPIE (St. Pete/Clearwater) working on my CFI and one of the school's Seneca I's had a nose gear jam. It was one of the most unbeleivable things I've ever witnessed. The MEI rated pilot was ~ 500 agl on final, cut the engines off and began to drop like a brick, I though he was dead! He went screaming into ground effect with fully feathered props and positioned them parallel to the ground with the starters and performed a perfect landing on the mains and gently set the nose down.
I was recently reading, I think it was aviation safety, about gear up landings. They suggested to never attempt to do anything like this and that it is just too dangerous. This MEI saved the owner dealing with $50,000 in prop strike damage and the plane supposedly has only $4000 in damage with a cracked nose cone.
What's up with Aviation Safety? Are they wise or not?
