Checks
- Dec 23, 2001
Let me share with you what I think is correct and have you guys sharp shoot it. I understand the pilot can use emergency authority to do what he feels is required but I would like to still understand what the regs want. Where I get hang up is on the airport as the clearance limit part. I have heard that you should fly over the airport at altitude then proceed to the IAF OR just fly direct to an IAF and do as listed there. Assume you have an IFR GPS on-board.
Thanks in advance
0. Squak 7600
1. If VFR, stay VFR and Land as soon as practicable.
2. Route:
Assigned, in the absence of an assigned route then-
Vectored fix, route, or airway, in the absence of such then-
Expected route, in the absence of then,
Filed route.
3. Altitude:
Highest of MEA, Assigned, Expected for the route segement being flown.
4. Leave Clearance Limit:
Clearance Limit is an IAF=commence descent and approach as close as possible to the EFC time(if received) or ETA(keeping in mind that ATC may have updated your ETA throughout the flight, assuming you were in radar contact or gave position positions prior to going NORDO)
Clearance Limit is not an IAF=
A) Destination Airport is the Clearance Limit: Fly direct to an IAF and descend+shoot the approach at your ETA(keeping in mind that ATC may have updated your ETA throughout the flight, assuming you were in radar contact or gave position positions prior to going NORDO). Hold at IAF if arriving before your ETA.
B)Clearance Limit is a non-IAF fix: If you have an EFC then wait until the EFC time then proceed direct to an IAF and commence descent and approach as close as possible to the ETA(keeping in mind that ATC may have updated your ETA throughout the flight, assuming you were in radar contact or gave position positions prior to going NORDO)
If you dont have an EFC then after arriving at the fix proceed direct to an IAF and commence descent and approach as close as possible to the ETA(keeping in mind that ATC may have updated your ETA throughout the flight, assuming you were in radar contact or gave position positions prior to going NORDO)
Thanks in advance
0. Squak 7600
2. Route:
Filed route.
3. Altitude:
