"No horn No land"
I agree with you. Personally I don't think they should say "No horn, no land" and require that of you. I think it's a good guidance to set up for an ideal landing. You may encounter that one landing where something happens and you need that little edge on speed to get you back up in the air. Basiclly for the same reason the NAVY pilots landing on the carrier punch the speed before they touch down, in case they bolter and need back up.
Also sometimes pilots may misjudge their height above the runway surface, stall the plane for the "perfect landing" and realize they were to high, only after they smack the cement from dropping 30 feet out of the air.
StealthyOne said:
One thing I noticed was a sign on the wall that said, " No Horn , No land" They explained that as a safety precaution, they didn't want any of they're students landing until they were going slow enough to were they heard the stall warning horn go off. Is this common prcatice?
Knowing this guys reputation I can almost assure you he has determined that the slowest possible landing speed will reduce tire and brake wear and slightly reduce his maintenance costs... It has nothing to do with "Safety" and everything to do with his bottom line... Honestly, I can't believe this guy is still in business...
IP076 said:
Fine and dandy until you do that once a decade short field approach and landing...then the trees at the other end seem to get bigger faster as well!
Whats that they say about a jet? 5% extra speed over the fence translates into something like a 20% increase in landing distance.
Let me clarify for you. When I made the statement about carrying a little extra speed on final, I was referring to flying in single-engine airplanes, NOT jets. We all know the importance of being on your target speed when landing jets.
And I would make an exception of my "rule" if and when I have to make that once-in-a-decade short field landing.
Flyguy2k8 said:
hey minitour i thought you'd like that one...it was just for you buddy!
I don't know why I get such a kick out of smartass or dumbass radio calls...thats probably what has me eyeing ATC...I envy you ATC guys at a busy facility...ORD, DFW, LAX, etc...very jealous...I'm sure you guys hear lots of stupid s*it all the time...
I once heard a story about an Aeromexico flight into ORD...kept screwing up the taxi readback...finally the lady controller just said
"Aeromexico XXX taxi to park everyone else STOP"
love that s*it...ah well...
OOH one more...
do you guys not just love those guys flying 172s and 152s that call up with that lazy old "jet voice"? They're so proud of it..."Hey listen for me today on approach"
(with that "I just woke up from a great f*ck and haven't gotten any coffee yet" voice) "aaaaaand cessna.....123...45...checkin in uhhhhh we're at four point five....like to request.....flight following ummmm to Tulsa..."
Lovin this s*it...
-mini
The difference being...?
I was visiting the Palm Springs area and go a chance to do my first flight in a AA-5B Tiger. I was told that, unlike the nice docile Cessnas and Pipers, they required a 2-hour checkout in the Tiger, mostly involving a whole bunch of landings. The reason? Well, they =used= to do a 1-hour checkout. Until they let a visitor fly the airplane after it seemed everything was okay and he ran it off UDD's 5000' runway when he came in just a little bit hot.
Target airspeed: it's not just for jets.
In your case, the decision to use extra speed may be a deliberate choice with a slightly higher defined target based on conditions, runway length, and all that other stuff that should go into the decision. Unfortunately, for way too many pilots, the decision is based on some dubious idea that it's okay and represents sloppiness at best.
Hey midlifeflyer,
I agree with you. I guess that's why they invented the POH, or atleast the PIM.
I also guess that's why they have that sweet little Takeoff and landing distance chart in there.
True, target speed isn't for jets. Every pilot flying any airplane should have a target speed AND landing spot. It doesnt stop with the phrase, "lets land". Performance planning is neccessity to effective flying. I'm just a PPL and I even I realize this.
Thanks for throwing your opinion in there, I agree!! Everyone feel free to watch for more of my humor, if you found it humorous at all...probably not. In any case, i've got a lot more where those came from haha. EVeryone take care!
You guys are KILLING me!! I should've prefaced that original statement that its just a general rule of thumb. Not something I live by! I'm accustomed to flying into 5,000+ ft runways, so I have the benefit of doing what I described. Any runways shorter then that, I normally hold REF speed and put 'er down as soon as possible to get the most out of the runways. (I'm one of these guys that hate getting to close to the departure end of runways on landing!)
I think instructors should teach student to use the normal landing procedure the same way consistently. If the runway is short then use short field procedure consistently. A runway so short that it requires stall warning before landing is too short. Students trained this way have a good habit pattern regardless of future plans & planes. One reason for not going below Vref prematurely when landing transport category jet is to avoid high deck angle and tail strike.
I don't remeber the last time i heard the stall warning go off on landing? Well may be the one time when I bounced and ....... Naaaaaaa. Not that time either.
Hey mini,
Heard a radio call coming back from Dallas love on a x/c where the a/c majically changed when the pilot corrected ATC.
"Cessna xxxx. You got a aerostar off you left when 11 oclock."
"Center, Im an aerojet not an aerostar."
"Correction Cessna xxxx you now have and aerojet off you left wing & decending."
Had another where a SWA was asking for a straight in to Will rogers. (ok so I don't know the identifer) He offered to pay for the straight in. Center was looking into. When center came back w/ an approval. The pilots kinda joked about how it sounded the were trying bribe a federal offical. All over the radio. It was funny.
