NJA How does this work?
bluejuice787
Airline guy here wanting to know how your schedules work at Net Jets. For instance, if I were hired and based in DEN on reserve would I simply sit at home and wait for the call? I am then airlined to my flight? Is reserve junior? How often are you used?
Thanks,
Juice
It's not like airline reserve. You will get a call by 1800 the night before. If you don't you call in by 1900. They must tell you the next day is a work day, or it's an off day. They can tell you to sit standby at home, or they can tell you to report for an airline. You will not be required to sit at home wondering what if?.. (unless you are specifically given home reserve)
The reserve schedule has typically gone senior because of the money. If the IBB passes it is still assumed it will go senior. We might have an additional 15 day schedule (if ibb passes) that is also expected to go senior, but if not, it will be assigned in reverse seniority order.. Hope this helps..
Thanks,
Juice
Go to the union website at www.ibt1108.com.
There you will find the current CBA and proposed 2007 TA. After reading, if you still have questions feel free to PM me. I'd be happy to talk to you about any questions you would have.
BTW, the vote for the 2007 TA is on December 7, 2007. We should know the results as soon as the volunteers are done counting the ballots. How long it takes depends on how many volunteers there are.
I found the current CBA, but where do you go to view the TA without a password?
You're right. Sorry about that. I'll have to get back to you.
Thanks,
Juice
Currently, there are two schedules that you can choose from. Keep in mind that the current reserve schedule isn't a "junior" schedule. In most fleets, the reserve schedule is full of senior guys because of the pay increase. In the airline world, the term "reserve" is used to describe what a very junior pilot will get. Not here. It's your choice which schedule you want to be on.
On the 7&7, you work a week and then you're off a week. Nice and simple. There's no guessing or wondering which days you'll be working and which days you'll be off.
On the reserve, you will work up to 18 days a month. You will have what are called "H DAYS." H DAYS are hard days off. You get 4 of those every month. The H DAYS are grouped together in groups of two. In other words, you will get two sets of two days off that are hard days off. You will know what your H DAYS are the month prior. The rest of the month is sort of up in the air. Although, you DO have some idea of what your days off are going to be...
The first way is to call the company and ask them what your "tentative" schedule is going to be for the next month. Although it's only tentative, it very rarely changes.
The second way of being able to tell is by looking at how long your previous tour was. If you last tour was 6 days long or less, then you know the next three days are going to be off days. If your tour was a whole 7 days long, you know that the next 4 days are going to be off days.
NOW.... let's talk about the new schedules that are coming in Feb/2008 if the IBB passes.
The 7&7 will stay the same. There are no changes.
There will be a 15 day flex schedule. You will get paid a little more than the 7&7 schedule but you will not know what your days off are going to be. What you DO know is that no tour will be longer than 5 days and that you will have at least 3 days off in between those tours.
There will also be an 18 fixed schedule. This will take place of the current reserve schedule but now the schedule will be "fixed" and you will know when you're working and when you'll be off the month before. This is also the highest paying schedule as well. This schedule will be a "biddable" schedule using the PBS system. All you airline guys know what that looks like. Seniority rules! The way it's set up right now, you'll be able to choose how long you want your tours to be, how many days off you want in between tours, and which specific days off you would like. Of course, the more picky you get, the more requsets will be denied.
Hope that clears some things up for you!
Schedule? What schedule? A day is either a work day or an off day. Whatever happens during that work day is akin to true randomness.
Hi!
Other posters have said they think on the 15 day reserve schedule you will work probably 10 or 11 days. 15 is the max.
On the 18 day schedule, apparently, you WILL work, in some format, 18 days that month.
10% of each fleet's pilots WILL be on the 15 day schedule, which is why you could get junior manned if need be.
The 18 day reserve will be up to 40% of each fleet pilots. It is voluntary. The only restriction, is that if less pilots bid for the 18 day schedule than were on it the last bid period (3 periods of 4 months per year), there is a limit on how much the % of the fleet pilots on the 18 day schedule can go.
For instance, if 30% of the Ultra pilots are on the 18 day schedule during a bid period, and ALL of them wanted off the next bid, that number may only be allowed to decrease to 25% of the pilots, so pilots may be junior manned in that situation also.
The above is scenario is pretty complicated, so please correct me if I'm wrong.
Have A Nice Day!
cliff
GRB
Pretty accurate on all accounts except the number of people allowed to leave the 18-day reserve is 10% measured against the fleet/seat, not 5%.
Cliff,
Do you work at NJA? I seem to remember this topic coming up not long ago. If you don't, I'm curious why you answer questions about NetJets instead of defering to those of us who do. It just seems a bit odd.:confused:
If you do work here, then please accept my appologies in advance.
265
Cliff,
265
Good question. you know what they say... "Jack of all trades. Master of none.":D
Cliff,
265
BWAHAHAHA!!! I just found it!!! Go read the third reply to the following thread!!!
Whats the best way to get to net jets
That will answer all your questions!
This statement dosn't make any sense to me.
There are only 2 restrictions as far numbers of pilots on certain schedules:
10% in your fleet AND seat are going to be on the 15 day flex. No more. No less.
No more than 40% can be on the 18 day fixed.
All the rest are on 7&7.
Fischman,
I think you misunderstood iamcdog! The third limitation is the amount of movement off of the 18 Day Fixed Schedule. The maximum percentage of pilots to move off of the 18 Day Fixed Schedule every bid period -- 3 times a year -- is 10%.
Hi!
Have A Nice Day!
cliff
GRB
Cliff,
I have to say: For someone that is not on the property yet, you seem to have a good working grasp of scheduling under the 2007 TA. There is no doubt, that it will help you once you are on the property.
Good luck!
Fischman,
Thanks IDE, yeah that's what I meant.
Hi!
I'm at USA Jet-my best friend from USAJet is at NJA. I'm sure I would love NJA if they hired me.
I get frustrated when I can't find out the info I'm looking for.
If someone asks a question about something, and no one else answers it, I will answer it to the best of my abilities, if I can help out.
I also know a bunch about Emirates, for example, even though I'm not there. I started researching them about 4 years ago, and just helped a USA Jet guy get hired there. I think they are very interesting, but I don't think I'd like living in Dubai enough to move there.
cliff
GRB
Hi!
cliff
GRB
Cliff, I WILL give you some credit. From the posts I've seen of yours, you seem to have a good handle on the NetJetsm contract. I just found it strange that you're always right there ready to answer any question related to NJA. I just figure that there are so many NJA guys who frequent this site, you would think they would answer the questions.
I'm just trying to think of some questions about USA Jet so someone from NJA can answer them!!!:D
Hi!
Well, maybe some of U guys at NetJets know when USA Jet will be getting -737s.
We here at USA Jet sure don't!!!
cliff
GRB
