nj aircraft
206amphib
So assuming one were to get hired in feb...what are the likely choices for aircraft at netjets? I'm assuming that they give you a choice based on where they have a need, yes? So what are the likely choices over the next few months? Also, once you complete the training in CMH, how much time till FSI?
A/C It varies....
Training....that too varies but you get a min of 5 days off after indoc.
Could be literally any of them, although I think the Ultra is probably not very likely, just because the fleet's shrinking. The BBJ and Falcon 2000EX won't likely go to a newhire either, as aircraft bids go to current pilots first, then to newhires. Since those two planes pay more to FOs, they're not likely to be passed up.
That depends entirely on the sim slots. In some cases, folks will go to FSI first because there's an open sim slot they need to fill!
Per the contract, you'll have at least 5 days off following indoc, and 5 off following sim training.
The Company is no longer sending newhires to FSI before indoc. That practice was stopped by the new VP of Training and Standards this year.
NJA Aircraft
Most newbies are going to the Excel/XLS or the Citation X. some slots in the CE-680 and Encore.
Oh and also the mighty HAWKER
XL for me,start class tomorrow ! Cheers !
If you look at the Jan 08 seniority list 26% of the last 100 newhires went into the Ultra and 50% of the last 30 newhires went into it. It's a shrinking fleet but upgrades are taking well over two years now and the non seatlocked Ultra FOs are abandoning ship from the Uboat and reinforcement troops are getting it.
Seems like a lot of new hires recently have been going into the Sovereign as well.
Have a seat in a Citation cockpit, try to imagine sitting in it for five hours. Then decide. :)
by that you mean any citation in general for five hours in a whole day or in a given flight? There are two hawker families in terms of avionics im guessing...collins and.....
so clearly the bigger planes have more to offer in terms of long term comfort...makes sense....i guess what I was really getting at was overall preference to a specific type. I've flown a few of the smaller citations, so even the xl cockpit would probably seem big to me....maybe I should ask this way; clearly different people like different types of flying ie long legs, a mix of long and short, whatever the case may be. Generally speaking, which planes do what type of flying? Clearly it can vary, i'm just generalizing....trying to get an idea of what to look to if given the opportunity.....
From what I've heard from my Netjets buddies, all of the aircraft types do some short-haul flights (even reposition flights from one NYC airport to another). The smaller aircraft don't have the range to fly nonstop transcon flights but they will often see both coasts during one tour (with stops in between). The Falcon 2000, Citation X, Sovereign, G200 and Hawker 800XP can do nonstop transcon flights and some do them more than others - the Citation X and Falcon 2000 fly the most transcons from what I hear. If you are a Citation X pilot, you will get to know the TEB/HPN-VNY route very well. The Citation X fleet is very busy because of its popularity with owners and because of its capabilities (when it is not in maintenance). Both the Sovereign and G200 fleets are popular and getting busier and they do transcons on most tours - the G200 has a wider cockpit than the Sovereign (probably more comfy during those longer flights).
The XL/XLS is the biggest fleet in terms of numbers and it is probably the busiest fleet - you will fly all the time. If you want short hops and not much flying compared to other fleets, the Citation Ultra/Encore and Beechjet will suit you well. I know a pilot on the Citation Encore fleet and he seems to spend a lot of time on the ground not flying (and he enjoys the time off).
The two Hawker 800XP fleets at NJA are either the Honeywell FMZ avionics or the Proline 21. They are also starting to take delivery of 900XPs which are also Proline 21 and will be flown by the XPC (XP Collins) crews. NJA treats them as separate fleets so the Collins pilots do not fly Honeywell Hawkers and vice versa.
Same airframe, only difference is the avionics package. I could be mistaken, but I understand that they are doing the same thing with the Encore and Encore+ and with the XL and XLS+.
That is correct. I used to be in the Encore but now fly only the EP.
Is the Pro Line 21 a big improvement in your mind? Anything else different with the Encore+?
Also, how does that work with owners? Are the Encore+ aircraft only flown for owners who bought shares specifically in Encore+ aircraft or is it flown interchangably with the regular Encore? How many Encore+ aircraft are on the way?
