Freddie Spencer
"That's Hot"
- Jan 26, 2004
the stick shaker comes on prior to a stall it doesnt mean the airplane actually stalled. the stick pusher lowers the nose to prevent a stall from occuring.Freddie Spencer said:410, stall with stickshaker and dual flameout, re-lights attempted.
CaptainBrazilia said:If you get up to 410 and cross a frontal zone where the ISA deviation changes significantly, you could end up having your hands full really quick...
Not speculating as to the cause of this accident...just adding to the mix of things people have presented here that could serve well in keeping us all more in the game.
QUOTE]
Not speculating either here about this case, but you've made an excellent point to always remember in general about why it can be dicey to struggle up to an altitude early, plod along, and think you're in the comfort zone just because you're burning off fuel. Our FFs in modern, smaller a/c aren't that much, and the temps can fluxuate quickly as you cross those zones. Thing can go to he11 in a handbasket in a hurry if you're high and at the edge of your perf envelope. You may quickly find yourself outside it.
And its not just temps. I remember the case of a Lear that stalled at altitude, where all it took was riding near the edge, a few bumps, and someone turning the heading bug in heading mode without using half-bank. Up there, it's possible for things to happen a lot quicker than a stick pusher can respond in time to prevent it.
I entered into the FMS the other day; FLPLN ALT = F410 with TOTAL WT = 40,000 lbs. at ISA +9 deg C and got UNABLE CRUISE ALTITUDE message. Unless you actually enter a temperature, it defaults to 0 degC which will not result in the UNABLE CRUISE ALT message.dondk said:So why make such a big deal about FL410? I still find it odd that the NTSB focused on that one issue so quickly.
If there is a possibility that your source is wrong, why post anything at all??Erlanger said:There's more, but I'll leave it for when it comes out in the final report, since it wouldn't be fair to the crew and just in case the source is wrong.
