Ndb
check six
Looking for the best method to teach students NDB course tracking on approach.
Having GPS moving map sure doesn't encourage anyone to use this primitive method much either.
Thanks,
Check Six
Push the head, pull the tail.
RMI's have made them pretty straightforward. Have them try one with a fixed compass card........FUN !
I learned "Heads Fall, Tails Rise"
Everytime I've had to think twice while flying an NDB approach, that really seemed to help me. The biggest thing to teach after that, is how to position the aircraft as to make the tail rise, or the head fall.
Ralgha said:
That's the most confusing thing I've ever heard! :D
You got to be kidding me?! Ok, actually lets break this down a little bit more, so I don't sound completly crazy!
When your flying inbound, you want to place the head of the needle on the desired bearing. If your flying outbound, you want the tail to be on the desired bearing.
To intercept a bearing, simply place the head where it will "fall" to the bearing, or the tail to "rise" to the bearing.
That simple. :D
The head falling confuses me, I don't get what you mean by that at all.
Push the head, don't get any simpler than that. Inbound on the 090 bearing, because of a right xwind you got pushed north of the 090 bearing and the head is on the 091 bearing, to correct, get on the other side (the 093 heading) and push the head of the needle back to 090, don't know how else to explain it.
Flying away from the NDB and tracking the same course on the 090 bearing outbound, with the same wind the tail would move up to the 089 bearing, you'll have to pull the tail back down by flying a 093 heading.
The beauty of it is you don't have to know what the wind is actually doing like I described, just push the head or pull the tail, works for the not so smart people like me, glad I never had to learn to use an ADF.
Just follow the head, that's where your bearing is if you parallel the ecourse, and then to intercept make sure the head of the needle goes past your relative north. When the head falls to the bearing, turn to it.
Flying outbound, parallel the course, and fly away from the needle untill the tail raises to your bearing.
To correct for wind, correction equals deflection.
Fun with NDB's
The best way that I have found to teach NDB's is to find a big room and make something into the NDB, the book on the table or the student or whatever, then you become the ADF and "fly around" using your arm as the needle and explaining your way through an approach or just an intercept. You will feel a little silly, but i had one guy who just never had any idea what I was talking about until i did this, after that he understood perfectly.
Always turn towards the head of the needle.
Sadly the FAA is looking to decommision 500 NDBs to make more money for WAAS approaches.
This and Piper Warriors with all glass cockpits=the dumbing down of instrument pilots.
I thought the FAA had abandoned the development of WAAS approaches last year after having too many technological issues??
Never Heard that, its in the 2005 AIM.
I saw the letter they sent to our airport about decommishing the NDB. Luckly our NDB is privatly owned, so the NDB approach may go away, but the NDB will still be on. And I can still make my students fly the approach (VFR only).
The old-schoolers may fret, but this is a good thing IMHO. Most ADF recievers in GA aircraft are junk anyway. Plus fix-to-fix GPS approaches are simple, way more accurate and have lower minimums. I dont buy the "lost art" stuff...I say good riddance
The NDB stations are not the problem, it's the NDB APPROACHES that should be done away with entirely. :D
I'd hate to see some NDB's go away, cause here in the midwest, they're your best source of navigating to a bunch of non-controlled airports!
...aaaah, the ol' NDB (tear glistens under one eye)....I'm gonna miss'em. I've made many thousands of dollars just goin' round and round the old beacon, trying to explain to someone who has never had to imagine his or herself in space and how he or she relates in motion to a fixed point....aaah, well, it was the worst of times and the best of times....sorry to see her go, but go she will.
Yes, she was inaccurate, and had lots of faults, but it seemed that once I could imagine the relationship, my total awareness in time and space seemed to grow exponentially, and I seemed to be more of the master of my fate....
I hated doing math, in high school, but you know what?...I can do math in my head, now. Kids today cannot do math in their head because they are allowed to use calculators in school work. Wal-Mart cashiers cannot count change if the computer goes down...
Progress is vastly overrated. I say bring back the 4 course range approaches. Required nothing more than two letters of morse code and a vivid imagination.
TDI (Tail, Desired, Intercept)
DHI (Desired, Head, Intercept)
Seems REALLY confusing until you get used to it.
Parallel the course with your heading and ALWAYS turn towards the head. Works going outbound and inbound. When you get in an airplane with and HSI always tune the OBS to the course you want to fly and make the NDB needle match the HSI.
The display in the aircraft has an influence on doing things.
An RMI allows you to look at your position using the RMI & needle as a plan view of your position w.r.t. the aid & desired track/bearing. Think of the instrument as an 'astronaut's eye view' of the aircraft, the navaid & 360 deg bearings around the aid.
In this view the following applies:
* The pivot point of the needle represents the NDB (or VOR if you have a VOR/ADF selectable RMI),
* The compass rose represents the earth underneath the aircraft, oriented 'heading up'. Similar to 'track up' on a moving map GPS.
* The aircraft is positioned on the tail of the needle, heading 'up' the instrument panel, and
* Scale is proportional to the most distant item to be visualised. Usually it's the aircraft range but it could be a bearing/distance to be intercepted.
With the above in mind the following information is shown or can be derived:
* Bearing from the navaid (radial if using a VOR data source) by reading the compass rose adjacent to the tail of the needle.
* Bearing to the navaid from the head of the needle
* Relative position & orientation of any desired bearing to or from the navaid.
* With a little bit of practice, the approximate heading needed to intercept another bearing/radial at any distance along the new bearing/radial. This is often referred to as the 'point to point' method. If you plotted this on a CR type flight computer then you can also read the track distance from your current position to the desired intercept point using the CR's underlying graticule.
Unfortunately this is difficult to describe without using diagrams or a model but I'll have a go. Bear in mind pictures.....thousand words...etc etc. so forgive me if prose fails.
Orientation first:
Scenario 1: Imagine flying North on a bearing/radial of 180 deg. That would have the RMI showing a 360 deg Hdg for the a/c, the tail of the needle would show 180 deg (the bearing from the navaid/radial the aircraft is on), the head would show 360 deg (bearing to the station). Try to imagine a miniature a/c mounted on the tail of the needle **always** pointing up the instrument panel & the navaid in the centre. The RMI would also show the 150 bearing from the station to be to your right, crossing at an angle from rear R --> front L & meeting your current track at the navaid. Do the same exercise for other bearings & try to picture where they are in relation to the a/c's position. You could use the wind side of a flight computer to do this exercise.
Scenario 2: Flying N. but positioned on the 270 deg bearing from the navaid. The RMI would still show 360 for the Hdg but the tail of the needle will be on 270 (ie bearing from the navaid) & the head on 090 (the bearing to the station). Still try to imagine the miniature a/c mounted on the tail of the needle. That would show the a/c on the 270 bearing and a right turn of 90 deg is needed to track 090 to the station. The 300 bearing crosses from front L --> rear R, the 240 bearing behind from rear L to abeam at the station.
Similarly to Scenario 1, picture other bearings on the RMI.
Interception:
Once you can picture the a/c position on the RMI and where a desired bearing is then it's also possible to see how much to turn to have a track that will cross the desired bearing at some point before or after the navaid.
A development of this is to use the circumference of the RMI to represent the largest distance in the intercept problem eg if you're at 20 nm & want to intercept a bearing at 10 nm then the circumference equates to 20 nm and the point to intercept would be midway between the circumference & the centre along the desired bearing. Using this then a straight line between the two points is also the track to get there. To find the required heading, match a parallel line that starts from the centre of the RMI & goes to the circumference - I use my pen or pencil. Whatever compass direction is under your pen is the heading needed to get to the intercept point**.
This sort of technique - particularly the orientation part - can be used on a standard fixed card ADF in combination with the the a/c's Direction Gyro. You'll need to use your pen (or count convenient divisions from the head/tail/left or right abeam to the head/tail of the ADF needle. Transpose the pen's orientation (or the same number of divisions in the same rotational direction as on the ADF) onto the DG. This is a pseudo-RMI since those same divisions you count mark where the ADF needle would be *if* the DI was also an RMI.
You could also rotate the ADF card if it's a rotating card type. I generally don't because I can't be bothered having to do it for every single heading change. I'd rather count the convenient divisions on the ADF & then count the same amount on the DI to find where the ADF needle would be
Once on a heading to intercept it's important to confirm that the heading is appropriate to achieve what you intend. On an outbound intercept the TAIL of the needle must be in a position to RISE towards the desired bearing (on an RMI) or rise towards the same number of divisions on a fixed card as there are between your HDG & the bearing on the DG. For an inbound intercept the HEAD of the needle must be on the opposite side of the nose as the heading is from the desired bearing ie HDG to the left of the desired bearing then head of needle to the right of the nose) AND in a position to fall to the bearing.
**In nil wind. Any wind will put an error in this no different to flight planning on the ground using track as heading techniques. Bear in mind it's all based on an NDB so utmost precision is hardly to be expected.
DC8flyer took the words right out of my mouth. I had to fly an NDB approach the other day. It's been a long time since I've done a full procedure anything.
Interesting you mention that, cause I was out at the local airport last week, adn sure enough there was a notice there from the local FSDO explaing how they were going to be decommishing our local NDB.
The notice said they were eliminating a large number of NDB's. Main criteria for decommishing is when the NDB is located on a field where other navaids are located (ie. VOR, ILS, etc).
