Bearing, when used in reference to a radio beacon, is the direction from the station.
When one uses the term "bearing to a station" one is actually referring to a course from the airplane to the station, rather than a station indication or reference. The same could be said of a bearing to a barn or lake. It's a course plotted from the aircraft to that object. When used in reference to aerial navigation by beacon, the using the term "bearing" in relationship to a station is technically incorrect; bearing represents the direction from the station to the aircraft.
A bearing to something is a straight line heading reference without regard to wind correction or current correction.
For uniformity, it's easiest to think in terms of radials and bearings as being the same. They aren't, in that a radial is highly directional and definable, while a bearing isn't, but consider their relationship on a RMI; they become the same.
I'm hoping that someone clicking on the thread will read the entire thread rather than just one response, as few responses are stand-alone answers.
Your final comment is the most important and critical one; if there ever exists any question, immediate clarification should be sought.
