Nautical Air Miles (NAM)
  • Thread starter Thread starter NoPax
  • Watchers Watchers 6
NoPax
NoPax NoMore
A few months ago, while studying towards my ATP written, there was a couple of flight planning questions relating to Nautical Air Miles.
Recently, I got to fly in a CJ1, from Austin to Dallas, and we climbed to FL220. The pilot wanted to climb higher - maybe FL280, and new to the whole jet experience, I didn't say anything (& we didn't get higher).
Its about 165NM, and I seem to recall the NAM chart for the 737 recommending a lower altitude (?).
What exactly are Nautical Air Miles, and how could a pilot flying Part 91 use this to their advantage - ie how can I explain that FL280 would be a waste of time?
NAM is Nautical Ground Miles corrected for wind.
Example, 1 hour flight, ground distance 400NGM, headwind component 50kt = 450NAM
What you are thinking of is optimum altitude for short flights. For the B737 there is a short cruise table that gives you an optimum altitude for that gives you at least 1 minute at cruise level.
FL 280 may be a waste in a 737, but i might be closer to optimum for a light jet, you'd have to go into the performance manuals to get the exact answer for that aircraft.
Hope that answers your question
Thanks.
I'll have to do a little digging in the manuals to find the optimum altitude for short cruise flights.
Now I just have to learn what all the buttons do!
Nautical air miles or often called ESAD (equal still air distance) is the NGM (nm ground miles) corrected for wind.
formula for NAM is;
NAM = NGM * (avg TAS/avg GS)
AUS-DAL = 200 nm (NGM)
TAS = 400 kts
Wind = 30kts headwind -
GS = 370 kts
NAM = 216 nm
FlyDouglasJets said:
Higher is not always better, if it decreases your Groundspeed substantially, due to a strong jetcore headwind.
Yes, and that concept compltely escapes some of the pilots. There have been far too many times that I have planned a flight at say 340 and at the first position report they say they're at 410......... The fact that you can go that high does not necessarrily mean you're gonna burn less gas. Just fly the damn flight plan already....
Whew, sorry
FlightOpsAB said:
Yes, and that concept compltely escapes some of the pilots. There have been far too many times that I have planned a flight at say 340 and at the first position report they say they're at 410......... The fact that you can go that high does not necessarrily mean you're gonna burn less gas. Just fly the dang flight plan already....
Whew, sorry
True dat, and niether is going great-circle direct the most efficient path from A-B. "Ahh....my FMC planned arrival fuel is showing less than :30 minutes, after I took that giant 1000nm direct routing about 2hrs ago". Where should I land?
You can't train stupid.
The Dude
OK, I think I'm missing something. I thought the shortest distance between two points was direct.
If you are talking about jet-stream winds, then I can see that, or am I missing something else?
You got it, a direct might be a good idea some of the time, but def not ALL the time. Jetstream, tropopause, etc. Of course the change in fuel burn might not be all that great, but it adds up.
We often deviate from the flight plan based upon two primary tools... the FMC fuel burn computation, and PIREPS. The goal of the flight is safety, comfort, on-time, and economy, in that order.
Situation 1: FP is 340. Cargo drops off significantly in the chocks. Winds aloft don't vary much from FL to FL. Higher = better
2: FP 360. Level 360, we "plug" 380 into the box. FMC says "yes fool, 380 will save 200 lb of fuel at destination." All else being equal, up we go.
3: FP 380. The ride is abominable. Pirep says 340 is smooth. Down we go to keep our flight attendants safe and passengers' lunches in their stomachs, where they belong.
4: FP 380. The forecast winds don't show up. PIREP says lower/higher is better. Once again, we change altitudes.
5: FP 370. Center says, upon initial climb-out, "The ONLY available altitudes due to traffic are 410 or 330. Pick one." This happens quite often.
It's like a battle. No plan survives first contact with the enemy. There are so many variables, it is surprising to me if we fly the flight plan exactly as it is printed.
edited: My language was inappropriate in the original post! :0
Agreed as well, but the impression I got from the thread so far was "Why don't the pilots fly the flight plan as it is printed, preflight?" Most of us assume that automatic position reports tell dispatch and others where we are, and at what FL. It seems about the only info not automatically sent is the ride conditions.
Get out your sextant
A NAM is one minute of elevation of a celestial body upon a great circle. 60 minutes of evaluation equals on degree. When shooting the North Star it will very closely approximates your latitude in degrees, it is on the horizon at the equator, and 90-degree overhead at the North Pole. This made it very easy for a navigator to convert celestial sighting to distances upon the surface of the earth.
No disrespect but, I think your on an entirely different book, nevermind page.
I was originally asking how a pilot could use the Nautical Air Mile, when planning a flight - specifically what exactly it is (I couldn't remember the formula - NM*(avg. TAS/avg. GS), and how I could explain this to a fairly low-time CJ1 pilot, when suggesting the altitude to fly at for shorter trips.
It would be like flying from Willow Run to Traverse City MI, and requesting FL340 - just because you can get that high, doesn't mean its the most efficient way to do it in your Falcon.
Interesting post anyhow. BTW is a sextant approved for IFR navigation in RVSM airspace, under part 135??? :)
