Mysterious tach markings
VNugget
suck squeeze bang blow
I was looking at pictures of Russian acro types, and found this Su-31 cockpit on A.net. See those stick-on markings with the decreasing numbers on the tach? What in the hell are they? I've been racking my brain over it, and the best I could come up is that it's TBO... heheh. If you want more than 3 hours out of the engine, better pull it back a little. If you only run at idle, you can make it all the way to 9 hours, if you're lucky ;) TrafficInSight suggested that it might be the maximum number of turns of a spin recovery before you gotta bail out... who knows :D
So... any ideas?
Looks like you got it.....if you look at the pattern it has those numbers on there for each maneuver.....
Pretty neat.
Pretty neat.
Yes...set max manifold pressure and then use the prop lever for power changes, that's what I would do.
Nah, I don't think it's that. First of all, the numbers on the pattern card are just the sequential number for each maneuver. Second, why would one not just adjust power with the throttle, like the airplane was designed? Especially on a boosted engine. Also, I've never done hard acro (or any acro on a constant speed prop) but from what I've heard, they just leave the throttle wide open for most maneuvers. Third, even if they were power settings for different maneuvers, they wouldn't be sequential, and perfectly spaced out right down to idle RPM.
Gahh.... I wanna know, dammit!
I think that thats the power setting for the given "G" loading, ie. lower setting for a higher G, to keep from over stressing the airframe.
I don't think that's very likely. The Tach is graduated in percent of max RPM
100% would be 2950 (crank speed) so you're saying ath at 9g, you would have to have the engine turning at 737 RPM or less (the 9 is stuck at 25%) in order to keep from overstressing the airframe? If it was some sort of airframe limitation don't you think it would be printed permenantly *in* the tach instead of stuck outside with little stickers?
If it was a structural load limit, I would imagine that it would be a airspeed markings not tach.
If you notice, all of the range markings are home made, and there are no slippage marks on the bezels.
If you were at 8 g's, where would you have the power set at?
I have expereince on French, English, Polish, Czech, Japanese and Russian foreign manufacturered aircraft that are experimental/exhibition category in this country, and this is typical of the markings. Instrument shops in this country can't remark the dials because they are marked with radium paint to facilitate viewing in dark conditions. The radium is now considered haz-mat, and most shops will refuse to open the cases on the instruments.
I'm not following you on the power setting for load factor thing. I could see a power setting for various maneuvers, but for G's. The amount of available load factor will be a factor of airspeed. Granted power settings will control airspeed, but having fixed power settings for G's just doesn't make sense to me. During aerobatics the exchange of potential and kinetic energy (altitude and airspeed) will be varying widely. One power setting would certainly not protect the aircraft from over stress in a straight dive compared to the same aircraft at straight and level. It just seems to me that using the markings for G's would only work in one pitch attitude. Everything above or below that pitch attitude would change the airspeed and therefore the amount of available G's.
Example: 2200 RPM at straight and level produces about 120 kts. At 120 kts I coulld briefly pull 6 G's, anything above that would increase the angle of attack beyond the critical angle of attack and the wing would stall. If I took the same aircraft in the same power setting, except this time, I put it in a dive. That same power setting would now produce much more airspeed and therefore have more available G's. It could overstress the airframe if the aircraft can't handle a structural load limit of more then 6 G's. Same power settings on both, but due to the changes in potentail energy for kinetic energy, the aircraft can now very easily exceed 6 G's.
no and no.
I wasn't criticizing, just trying to use a little deductive reasoning to answer the original question. If it came across that I was being rude in my post, that was not my intention. I'm as curious as everyone else as to what the answer is. If your answer is right, then great. I'm just trying to test the various theories to see what works.
No harmful intent.
well, just off the top of my head, I'd think I would have a fairly high power setting, because in an 8g turn, I'd be bleeding energy pretty rapidly. But then I've never flown an unlimited aerobatics plane.
I have never heard of power setting being a limiting factor for acceleration loads. Why would it be. If you're pulling 8 g in a turn, you're pulling 8g that's what the wings feel, they don't feel the power setting.
Additionally, RPM in generally used very little in power settings compared to throttle setting. Remeber this is an engine with a constand speed prop. Manifold Pressure usually plays a much more sgnificant role in settng power. So why aren't there little "g" stickers on the maniold pressure gauge?
So, let's accept for a moment that you are correct. look at the stickers, they are evenly spaced, so the nmissing "2g" sticker, would be at about 92 percent. meaning that if you pull 2 gs, you gotta pull the power back in a 2g turn, or you risk damaging the airplane, according to your theory. Now, I dunno about you, but every plane I've flown is capable of 2 gs, 60 degree bank is 2g in a level turn. It's within the normal operating envelope for every certificated airplane. And I've never heard the you have to reduce power in a 2g turn to avoid airframe damage. So, you're saying that a power setting that any normal or utilitary category aircraft will withstand with no difficulty, will endanger the structire of an SU-31, one of the toughest unlimited aerobatics planes made?
I agree, I don't think we've hit the nail on the head yet.
My guess, and it's a BIG reach, is that it could be a limitation related to rpm vs. altitude in meters, or perhaps some other cooling issue. Could it be settings for the "gill shutters" in front of the cylinders?
I'm doing some searching, but don't have any other ideas...yet.
Lilah
I like that idea, but it seems that would be overly complex for engine cooling. Having 10 different settings of cooling gills.
SOMEONE MUST KNOW!!!
Well, if it should be any valuable clue, there's pictures of other cockpits without those markings, so they're not essential.
I asked a friend who has a CJ-6; and he didn't know, so I've tried going to the source. We'll see if Luiz knows english (my portugese isn't that good), and replies to my email....
Lilah
Lilah
I spent about 45 minutes last night reviewing a lot of what I could search on www.google.com about su's and tachometers.
The Re-occuring theme seemed to be tach generators and tach's running backwards although I couldn't find a direct source saying this or that.
Maybe Luiz put a different tach generator in and now the tach indicates reverse...his home brew markings could be in percentages of 100% RPM.
THat's the first theory that makes any sense to me
Hmm... so far the best idea... but why would he stop at 9?
If this were a problem, wouldn't you think he would also repaint the green arc/red lines? They appear to be painted on the outside of the instrument and non hazardous.
I think this is what FNFAL is referencing....​
The tale of the backwards tachometer
The modern way to make a tachometer is to put something electronic in the engine that generates electrical pulses as the engine turns and ship these pulses via a wire to a unit mounted in the instrument panel that counts them. Of course, this approach is much too modern to use on airplanes. The airplanes most of us are familiar with have a gadget in the cockpit with a disk inside which gets turned in proportion to the speed of the engine, and the rate of turn of this disk is registered on a needle displayed on the gadget's face. Typically, this disk is turned by a cable, and the other end of the cable is mechanically driven off the accessory case of the engine. Basically, the engine twists one end of the cable which makes the other end twist the disk inside the tachometer. The M14P uses a similar scheme, except that instead of using a mechanical cable, it uses a 3-phase electrical signal. A "tach generator", which is 3-phase generator, is driven by the engine, a 3-wire electrical cable carries the signal to the tachometer unit in the cockpit, and inside this unit is a 3-phase motor. The 3-phase motor turns at the same rate as the tach generator, and the motor turns the disk that moves the needle. Some might complain that this is the heaviest possible way to make a tachometer. Some might complain that the drive shaft for the tach generator tends to get wobbly, the generator tends to vibrate against the engine mount, and other such mechanical things go wrong. All these complaints may be true, but they are the routine kind of complaints about typical aircraft technology. And, anyway, a failed tachometer in flight is not a first-class problem. I've had a more amusing kind of failure. First of all, why did they use a 3-phase generator and a 3-phase motor? Well, if you had an ordinary 2-phase generator, there would be an ambiguity about which way the motor would turn. Whatever way it happened to start going when you fired up the engine, that would be the way it would continue going. With a 3-phase system, the direction of the motor is completely determined by the direction of the generator. Here are the symptoms of the failure I had. I would start the engine, and the tachometer would read 0. It would stay that way for some unpredictable period of time. Usually, it would eventually start to indicate an r.p.m. that would bear some relationship to the engine r.p.m. Sometimes, the tachometer would start working perfectly normally. But sometimes it would do something pretty strange. At idle, the r.p.m. would read 90%. As I brought up the power on the engine, the r.p.m. would read less and less. At full power it would read 15%. Given the narrative above about the 3-phase and 2-phase systems, I guess it's pretty obvious what had happened. One of the 3-wires had disconnected itself from the tach generator, so sometimes the motor in the tachometer would get started going in one direction and sometimes it would get started going in the other. The fun thing about all this was that, as soon as the tachometer got off 0, I would be OK. You see, it didn't take me very long to learn how to interpret the backwards indications of the tachometer needle. You idle at 90%, take off at 15%, and cruise at 45%. What's the big deal?
Blatently stolen from:
http://home.att.net/~sethfuller/fredabramson.html
I think we may have a winner! Thanks!
P.S. Really cool article, too. If ya can't rent'em, you can read about 'em, I guess.
