Just as an FYI...I acquired some BPPP training material which, naturally, has information specific to the Baron models...I'm not saying it proves anything one way or the other, but it does put some very specific information into the equation.
A few quotes (all emphasis/punctuation is theirs):
*The bank angle is critical; too much or too little can cause loss of control at speeds well above Vmca!
*There is NO instrument in the aircraft to indicate the proper bank angle!
*A yaw string attached to the nose of the plane will provide the proper information on bank angle.
*An increase in altitude...lowers Vmca without significantly changing the stall speed, indicating that for most all light twins, there is some weight/altitude combination where Vmca and Vs are the same. For the sameple, this crossover occurs at half fuel, mid CG and 3000 feet--the exact conditions at which most multi-engine Vmca training demonstrations are performed.
*DECREASING the bank angle AWAY from the good engine INCREASES Vmca AT THE RATE OF 3 KNOTS PER DEGREE OF BANK ANGLE.
*If the pilot inadvertently or instinctively tries to hold the wings level in an engine out situation, Vmca CAN INCREASE AS MUCH AS 20 KNOTS. THE AIRCRAFT COULD BE UNCONTROLLABLE AT SPEED AS HIGH AS Vyse. This situation WILL EXIST if the pilot tries to maintain heading with the ball centered!
Additionally, a Prof M.R. Byington of ERAU conducted flight and wind tunnel tests on a Crusader, a Seminole, and a 58 Baron, with a 3-foot length of yarn as a yaw string and a "large inclinometer" in the cockpit, at a 5000' density altitude. Results for the Baron include:
1 degree into the DEAD engine--0 ft/min climb
Zero bank--50 ft/min climb
2.7 degrees into the good engine--150 ft/min climb, yaw string centered, ball about .7 out of center
5 degrees bank into the good engine (max allowed by FAR for Vmca demo)--75 ft/min climb
7.5 degrees into the good engine--0 ft/min climb, but no rudder force required. Vmc is "vanishingly low", and he recommends this configuration if you're flirting with Vmca rollover.
Exactly how that would translate to an engine-out climb after takeoff from a 1000-ft D.A., I don't know...obviously the total climb numbers would increase across the board, but would the INCREASE change?
Well, now you know as much as I do
Fly safe!
David
