T
Traumahawk
I saw this question a while ago somewhere else, wondering what you guys would make of it.
Simulating engine failures in twins. When I did my training is was with the mixture below 3000agl....and usually fuel selector above.
I think these methods are the most valuable tools we can use to create an experience for a new student getting into the twin engine world.
Many people dissagree and support only using throttle retarding to simulate any engine failure anywhere, and, sometimes, with good reason. Many say if you were to crash due to the mixture cable breaking etc... you would be held under wreckless endangerment ect... also saying cutting these two ways is just too risky.
Now, personally, mixture/fuel selectors was the way I was taught. It is the way all the examiners in my area perform the checkride. In addition, lycoming even specifically states it is much easier on the engines to use mixture cutting rather than throttle reatarding due to 'a cushioning by air pressure of the pistons - providing the throttle is open.'
Another point to remember, how real is pulling a throttle on your student on the roll? You move his/her hand out of the way, yank one back and almost make the decision for them.
In the air, the same applies, but instead of 2 throttles sitting side-by-side, one is fully closed, the emergency procedure and line of questioning just got shorter and easier. Whereas a fuel selector cut may induce some coughing, yawing, Suprise, as can a mixture cut on the roll while you block them both with a cupped hand.
Too risky, possible lawsuit??
You could also argue whether it is 'worth the risk' actually stopping an engine in flight during training and the flight test, or whether it is worth doing the 'Vmc demo', just in case an engine fails at the wrong moment, or doesn't re-start. I believe that these risks are worth taking, and indeed nescessary to breed a competent ME pilot.
I have heard of pilots being sued for wrecking an aircraft while practicing crosswind landings in a taildrager, because it was "foolish and reckless to practice purposefully with a crosswind situation."
At this point, I feel that if we eliminated every risk and worried about every potential lawsuit(that you probably shouldn't usually be worrying about in the air) then we wouldn't get farther than the ramp boundary, and thats after a 4 hour preflight and mechanic's inspection. I do think we can increase the realism and experience level of a new twin student by using the 2 methods named, especially students coming from 'pilot factories' who often lack any form of new, supporting experience to fully and properly excercise the ratings held. I'm, in some cases, one of them.
What do you guys do?
Sorry for the novel folks.
Safe flying'
---T-hawk
Safe flying'
---T-hawk
