Multi-Engine Commercial Checkride
fussle
Oh John...
I have done a search, but didn't find much. So I was wondering if I could get some of your experiences for a multi-engine commercial checkride (instrument). I will probably begin training for this at a local airport in a 310R in a week or two. Right now I have been reading the POH and going through "everything explained for the professional pilot," as well as the jepp multi-engine book. I know I need to know the systems, but how in depth do I need to know them? Any other pointers would be appreciated.
Know COLD:
Prop
Engines
Hydraulics
Breaks
Gear
Vacuum
Pitot/Static
Electrical
Fuel
When I say know it "COLD" I mean...know how it works, what it is and what it does...drawing, IMHO, goes a bit too far on some systems *cough*electrical*cough*
Also know:
What is, affects and changes Vmc
Obviously know limitations in the aircraft
The 310R is a fun 'lil plane...fly 'r right and she'll do a lot for ya.
Have fun!...that's the most important part of flying twins.
-mini
yeah know everything that minitour said.. know your t/o brief backwards and forwards. know how to use all of the performance data on the airplane and be able to apply it. be able to explain vmc, and se engine aerodynamics. basically know your $hi1. good luck man.
Dead food, Dead engine
Mixtures, Props, Throttles, Flaps up, Gear up, Identify, Verify, Feather
Do the above SLOWLY yet assertively. Moving too fast can kill you!
I'm also assuming that he meant "dead fooT, dead engine"
What he said...there's no "!'s" on a checklist. Run the checklist swiftly, but not hurried.
And also the guy that brought up takeoff brief and performance data...know accel/stop, what it is and what it gives you...know accel/go, what it is and what it gives you.
I should have asked...is this an initial Commercial or a Class Rating add-on?
If it's the initial, obviously, you'll need the FAR 119 stuff in your head, VFR planning, maneuvers, etc. If it's the add-on, there's not much to the actual flight...some turns, SE Work, landings...enigne failures.
Oh...and know where the split is and how it works on what is a "light" twin and what isn't. Then know how "light" twins are split and how that works and what it means.
IE.
12,500#+ = Not your light twin
<12,500# = Light Twins further split by
6,000#+ = Has to show single engine climb rate
<6,000# = Has to determine single engine climb rate
Show and determine are two different words...why?
Know the accel/go gets you to 50' only.
There's not a lot to ME flying...but lots of knowledge. I guess, the more advanced they are, the more you become a systems manager...it all starts with your first twin. Like I said, the R310 is fun...fly 'r right and she'll do a lot fer ya.
Good luck and have fun!
-mini
Read, speak, and understand English. The regs don't say anything about being able to TYPE it! :nuts:
THis is what my multi ride consisted of...systems information, Vmc, Vspeeds, weight/balance, T/O & landing distance, and engine out scenarios,Steep turns, slow flight, stalls, Vmc demo, engine shutdown and restart, crosswind T/o and lands, short field T/O and land, eninge out landings from base and from final, lastly I shot the ILS down to circling mins. on one engine
My oral wasnt too bad.. bout 30min. flight was 1.3
There are three types of information in aviation:
1. Things you need too know
2. Things that are nice to know
3. And who gives a $hit!
This is the biggest bit you will need to know after an engine failure that you MUST commit to memory:
"Roll Wings level, step on the ball"
"Heading and altitude (till blue line = Vyse)"
"Mixtures, props, throttles forward"
"Gear up, Flaps up, boost pumps on"
"Identify (Dead foot dead engine), verify (Confirm and slowly close affected throttle), feather (confirm and slowly feather dead engine)"
I have signed off well over a hundred students and at least half of them have been multiengine students of some type. This mental checklist works! When and if you have time, back it up with a real checklist.
Back to my three types of information, the mental checklist is something YOU NEED TO KNOW as well as you systems and general knowledge. Knowing EVERYTHING about everything falls into the category of who gives a $hit. Just have a good general knowledge of how and why things work, but dont be fooled into being able to know everything about it.
Also just as a nice technique to make you smoother at dealing with an angine failure...Dont be fooled into pitching for blue line right away, unless you have a failure after takeoff or if a climb is needed. If enroute maintain altitude until the airspeed slows to blue line, than maintain that speed. Dont worry about loosing altitude at this point, this will buy you the most time from there on out.
Good luck with your training!
This is pretty much the CPDIVE acronym I've used in the past. Works well.
Control - Put in appropriate aileron and control inputs to establish zero sideslip.
Power - Mixtures, props, throttles to full.
Drag - Flaps up, gear up.
Identify - "Dead foot, dead engine."
Verify - Retard throttle for the dead engine.
Evaluate - Feather or troubleshoot to try for a restart, depending on the situation.
Or, my favorite that simply combines the "control" and "power" steps. Care is needed in a higher powered airplane though, else if you don't control properly while you're cramming, you can get into all sorts of trouble:
Cram
Clean
Identify
Verify
Evaluate
