Monday laughs
bobbysamd
My mother-in-law forwarded this to me:
Subject: Fw: Aircraft Maintenance Problems and
Solutions
Never let it be said that ground crews and engineers lack a sense of humor.
Here are some actual logged
maintenance complaints and problems, known as "squawks," submitted by QANTAS
pilots and the solution
recorded by maintenance engineers.
By the way, Qantas is the only major airline that has never had a fatal
accident.
P [in list below means] - The problem logged by the pilot.
S [in the list below means] - The solution and action taken by the engineers
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except autoland very rough.
S: Autoland not installed on this aircraft
P: No. 2 propeller seeping prop fluid.
S: No. 2 propeller seepage normal. Nos. 1, 3 and 4
propellers lack normal seepage.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Autopilot in altitude-hold mode produces a 200-fpm
descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick
S: That's what they're there for!
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windscreen.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be
serious.
P: Target radar hums.
S: Reprogrammed target radar with words.
P: Mouse in cockpit.
S: Cat installed.
