Ladies and Gentlemen, our future president....
I guess Boeing have to build a new airforce one with roll down windows for our new president...
http://elections.americablog.com/2012/09/mitt-romney-upset-that-airplane-windows-dont-open.html
Because apparently he’s never watched a movie or TV show in his entire life.
I meant to write about this earlier today, but was busy dealing with more serious news. Still, what is this guy thinking? He’s a walking gaffe-machine of late.
In his latest, Romney was talking about his wife’s aircraft that had some serious trouble last Friday with an electrical malfunction and had to conduct an emergency landing.
From the LA Times:
How did Mitt Romney not know any of this? I had to look at the exact temperature but I knew it was below -40F. I also knew the cruising speed was around 500pm, and that the air pressure was pretty darn low up there in space where there isn’t much oxygen to start with.
What was Romney thinking to even say something this dumb? I’m increasingly thinking that the man is not the brightest bulb.
From the LA Times:
“I appreciate the fact that she is on the ground, safe and sound. And I don’t think she knows just how worried some of us were,” Romney said. “When you have a fire in an aircraft, there’s no place to go, exactly, there’s no — and you can’t find any oxygen from outside the aircraft to get in the aircraft, because the windows don’t open. I don’t know why they don’t do that. It’s a real problem. So it’s very dangerous. And she was choking and rubbing her eyes. Fortunately, there was enough oxygen for the pilot and copilot to make a safe landing in Denver. But she’s safe and sound.”
As HuffPo points out, Romney has his facts slightly off:
The main reason airplane windows don’t open is because there isn’t enough oxygen at cruising altitude to keep passengers alive. (The fear of window or cabin failures, which would lead to potentially fatal hypoxia, is why many planes are equipped with emergency oxygen masks.)
“You can’t find any oxygen from outside the aircraft to get in the aircraft, because the windows don’t open,” Romney told the Times, suggesting that additional oxygen in the cabin during the electrical malfunction could’ve alleviated the problem. In fact, if there were an electrical fire on board, additional oxygen would have fed the flames.
Here’s another reason the windows don’t open at 40,000 feet: Because you’re traveling at 550 miles per hour, which can slam a window awfully hard on your finger (in addition to ripping the window right off). Another reason, the air temperature is 70F below zero, which might give the passengers a slight chill when the guy in front of you refuses to close his window and the 500 mile per hour -70F wind is blowing in Mrs. Romney’s face. (Then there’s the air pressure differential…)“You can’t find any oxygen from outside the aircraft to get in the aircraft, because the windows don’t open,” Romney told the Times, suggesting that additional oxygen in the cabin during the electrical malfunction could’ve alleviated the problem. In fact, if there were an electrical fire on board, additional oxygen would have fed the flames.
