Mitsubishi Diamond
cands
Active member
We are looking to add a diamond to are flight department so any info good or bad
Thanks for the help.
The Diamond is a pretty good airplane for the money. It has decent speed (we saw an average of 400 ktas) and a good cabin for a light jet.
It is sluggish and under-powered in hot temperatures. We operated our Diamond IA in the Southeast out of a 5300' strip at 1000 MSL. On a 30C day, the TOFL is 5300' at a 14,500 lbs (1000 lbs under gross).
Our aircraft didn't have the increase landing weight mod, so we were restricted to 13,200 lbs. Our BOW was approximately 10,200 lbs. We did a lot of short hops with an average pax load of at least 5 people, so we couldn't tanker fuel.
Our DOC's were right around $1,000 per hour.
The range is limited. Depending on winds, our range was approximately 900 nm. Our max fuel was 4200 lbs. We consistently saw the following fuel burns:
1st hour: 1500
2nd hour: 1200
3rd hour: 1100
*Note: This was before D-RVSM.
We planned to be on the ground within 2 hours 45 minutes.
Depending on your mission profile, it can be a good airplane. I hope the information is helpful. If needed, I'll be happy to share more specifics.
If you can get one without reversers you can add AT LEAST 20 knots to that TAS. Although, no TR's makes for a sporty landing on a short wet runway. Better put it down and hope you don't hydroplane right off the end.
MP
The example that I've spent the most time in did right around 400ktas, and that is without the TRs... I flew three serial numbers total, one of which I recall did about 410ktas, but that was about it. The other was around 400 as well.
I like the Diamond, but have little else to compare it to, so I wouldn't try to evaluate it... Personally I thought it was a bit heavy in the controls, at least compared to the Citation 500 and King Air 350, but those are very different airplanes...
I've had way too much pucker factor trying to land an MU300 on a short wet or snowy runway with no TRs. It once took me the whole 7000 feet to stop. If you must.... get TRs on the thing.
I have been told many times that a Diamond with out T/R is capable of landing at airports where you can not take off.
HEADWIND
